as it says sound like air con pump rattles on tick over, disapears after1200 rpm the air con is not cold either no click from pump when button press also no cold air in car , is this because its empty or would it be bearing . took the aux belt off and it stopped rattling pulleys spin ok and are not noisy . sounds just like a clamp loose on an exhaust ( best i can discribe )
