Using kickdown is no different to dropping down by 1 or 2 gears in a manual car (or pulling the - paddle a couple of times on your auto) - just puts you in a lower gear at higher revs, and therefore in a more responsive part of the acceleration curve.
It's just another tool that you can use as part of your everyday driving, along with the ability to change the gear range that the car can select with the paddles, or using S mode rather than D, or using the Snow or Pwr settings, or using Cruise Control, or switching off traction control, etc.
They are all appropriate settings in different circumstances, and as a good driver you will want to know what each of them does and when is the right (and wrong) time to use them.
I take it the lex is the first auto you've driven then ? I now drive a auto Mercedes 32ton eight wheeler,the kick down on that is not as good as my lex though !!!....
Allan
Yeh Derek, the 12 speed Merc Arocs only drops from 12 th to 11 th when I use the kick down and normally the dash computer says NO !!!.......
Allan
