Windscreen Replacement
I have had a New Model RX300 since July am not going to have another windscreen fitted.
First of all, I was hit by a firework on Bonfire Night. That caused a crack about 18 inches long on the passenger side.
Got that replaced with a 'Lexus' windscreen last week. Apparently you can only get that size windscreen from Lexus at the moment.
Then this morning I was hit by a stone on the motorway. Another crack, this time only about 9 inches long.
Are Lexus windscreens at fault or is it just my bad luck. I have only done 19,500 miles so far.
Night-Time
I had my windscreen replaced about 6 weeks ago.
Driving along a road at 45-50 ish I heard a splat, looked at the windscren and saw a white line. Assuming it was bird ^%&( I washed the screen, but the white line would not budge.
Upon close inspection the screen had cracked from underneath the top seal on the passenger side. There was no signs of stone damage, so I could only assume it had been poorly fitted.
Oxley's of Douglas replaced the screen under warranty. The screen took 3 days to arrive.
I/Oxleys have not heard of any other problems so obviously not a recall problem.
