I bought the Drivepro 3 months or so ago and it's brilliant. The only thing I would recommend is paying £6.99 for the suction holder rather than the self adhesive one that comes with it. It also makes it easy if you want to put it in another car. It's also HD and wifi.
Nice to see I bought the one that came out on top, it's often the other way round!
Go for Blackvue, I've installed the DR600GW HD its HD video at £199. Build quality is superb and the unit is discreet.
Highly recommend it.
Second that, I went for the DR650GW 2ch front & rear. Easy to install and easy to operate with the wifi.
I've just bought a DrivePro dash cam and am hoping to fit it over the weekend. Does any one have any advice on the easiest place to find an ignition-supplied +12v lead to tap into? What trim panels would I need to remove to access it?
Thanks for any advice you may have.
