Remote Re-programnming On Gs
I'm not sure if you can program a new remote. A dealer may be able to order a new remote which will work as they may have records based on your chassis number. Otherwise a new receiver unit and remotes will be required which will be expensive although fitting shouldn't be too expensive and all the wiring is already in place.
It may be worth you speaking with your local dealer or Chris Shipley to find out your options.
