• Join Gold & Save!
      Join Gold & Save!
    • Massive Choice on Lexus Parts
    • Get Your Club Gear
      Get Your Club Gear
    • Save Up To 15% On Your Lexus Insurance!
    • 1000's of Lexus For Sale
AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Lexman59
Customise Image
20 posts in this topic
I have been trying to customise the image on start up and shut down screen following the instructions as per the navigation manual. I have loaded images onto a USB which are less than 10 MB in size, JPG format and in a folder named Image and copied from the USB as instructed but when i select the image it comes up with the broken image/incompatable symbol. Has anybody else done this succesfully or am i missing something :wallbash:
I've got it working on both cars and first time as well.
The folder has to be called StartupImage (case sensitive & 1 word) or Image depending on the year of the car
The file has to be JPG with .jpg or .jpeg tags
USB should be no more than 128gb and formatted to FAT32. It will not work with NTFC. In other words won't work for MAC usb discs
Everything is correct apart from the file name, handbook says it can be up to 32 characters so I'll edit the file names and give it another go.
Cheers
Cheers
I believe the pics are also size and pixel limited so worth playing around with them as well.
I have edited the file names to 4 letters, they are jpeg approx 4mb in size and the USB is FAT32. The folder name is Image as per Navigation manual, when i go to customise image/copy from USB the images appear correct so its copying them alright  its only when i click on them to select to set as start up image that it goes wrong and i get the broken image symbol :helpsmilie:
OK so you copied them to the car and its not showing the broken image symbol on the right side but when turning the car on, it shows broken image symbol?
Best thing to do is probably start over again as I don't know why its doing it unless its too big or something like that
Try it again and set it to "both" and turn the display off, see if it works that way and it saves you from turning the car on and off each time.
Make sure the image is 800 x 480px btw. I found that works best
No it is showing the broken image symbol on the right hand side with the image files listed on the left hand side, it's just a list of the images and when I select one the broken image symbol pops up on the right hand side. Handbook says images can be up to 10mb in size and the 2 images I'm trying to copy are 4mb each. I think I gave you the impression that they are copying but they are not, they are just coming up in a list. I'll try again and if it fails I'll take a photo of the screen so you can see what I mean.
IMG_0823.thumb.JPG.633a61602d5c61ede0ed8464c4a60096.JPGThis is the image I get when I click copy from USB followed by this image when I select the image to be copied.
In the handbook it shows the actual image, not the camera icon when selecting the file to copy over. It appears the car cannot recognise the file.
Can you post a screen capture of the contents of the USB? i.e. the file listing with extensions?
Agreed with above
Mine shows the actual pictures. Are the files OK and uncorrupted?
Also is the file originally jpg or been converted to jpg from another format?
They are jpeg converted from a RAW file original, I shall get my camera out and take some original jpegs and see if it will recognise them, thanks for the replies.
No luck, jpeg straight from the camera exactly the same. Never mind I'll leave it for now and just enjoy the car 😎
That's really odd. Keep playing around. Might be worth trying amother usb
Here is a copy of my one that I use.  You could try that just as a test.
I'm sure my son wont mind.....
@Lexman59 might have some trouble explaining that to the other half when it pops up for the first time!
1 person likes this
Well  would you believe it the images i have been trying to copy have been taken with a very expensive Nikon SLR.  So i had an idea and i thought i'd try some images from my iphone and guess what, they copied no problem. :yahoo:
1 person likes this
Can't believe that! Camera must be too complex for the car to decipher
Probably something to do with how the camera creates the jpeg file conversion.
If the file size is only just under 10MB that is still quite big for an image. Suspect the Iphone ones are a lot smaller file size.
The iphone images are about 3MB, i had reduced the Nikon images to a similar size but they still would not work.
  • Recently Browsing   0 members
    No registered users viewing this page.
