If your like me, the best part about owning a Lexus is the nice toys and technology that Lexus offer.
I've recently swapped my IS220D SE-L for a IS250 SE, The SE-L was fitted with the illuminated door sills that light up "Lexus" when you open the doors, a really nice feature which should be standard in my opinion.
Unfortunately my 250 SE only had the basic plastic sills that look a bit cheap on a Luxury car so i pulled off the plastic ones to find that the cars are fitted as standard with the plug for the illuminated sills, so I thought I could just buy the illuminated sills and plug them in.
post-50607-0-23096900-1419955799_thumb.j
Unfortunately it turned out that this is not the case, all the cars do indeed have the plug however the plug is only wired in on the Luxury and sports spec models, to get around this problem you need to do some basic home wiring which I will show you now.
Please note: I take no responsibility for any damage done to your vehicle while following this guide.
For this modification you will need the following:
1-2M of Auto Wire
4x Scotch Locks
post-50607-0-42964600-1419956215_thumb.j
A Pair of Bull Nose Pliers
A Pair of Snips
Stanley Knife/Craft knife
Step 1:
Remove the existing door sills to reveal the wiring loom underneath ( A bit of brute force pulling straight up will remove the sills)
post-50607-0-21253600-1419955851_thumb.j
Step 2:
Using a Stanley Knife or Craft knife, carefully cut away the electrical tape that covers the wires that go into the door sill connector (Be particularly careful not to cut into any wires in the loom).
post-50607-0-33292400-1419956058_thumb.j
Step 3:
Take your Auto Wire and 1 scotch lock and Scotch lock your auto wire and the White wire going into the Door Sill Connector together (Leave the blue wire as it is).
post-50607-0-76505700-1419956194_thumb.j
Step 4:
Remove the interior trim that covers the seat belt tensioner system (to aid this process put the seat in the fully back position and the backrest all the way back, and open the rear door. Again some force will release the clips holding the panel on).
post-50607-0-53293700-1419956391_thumb.j
Step 5:
Locate the wire that connects to the Door switch, it sits on the inside of the pillar behind the switch. (A White Wire on the drivers side and Purple on the Passengers side, shown in the image above).
post-50607-0-15947200-1419956496_thumb.j
Step 6:
Trace your auto wire around the current loom to reach the Door Switch wire behind the seat belt panel. (when doing this ensure that your auto wire cannot rub on the seat belt as it moves back and forth during use).
Step 7:
Take a Scotch lock and scotch lock the Door Switch wire and auto wire together (Ensure you don't short out the wire on the vehicle's body work while using metal tools. I also wrapped some electrical tape around the scotch lock to ensure nothing metal would contact the bodywork in the future).
post-50607-0-64161600-1419956710_thumb.j
Step 8:
Plug in your illuminated door sills to ensure they are working correctly, when you push the Door switch the Sills should shut off and then light up when the switch is released. (If your Sills don't light up please check to see if you have your interior light switch set to come on when the doors open).
Step 9:
When you are happy that everything is working correctly, push the interior trim panels back into place. Some pressure on the areas should clip everything back in to place.
Finished Product.
post-50607-0-83992300-1419956965_thumb.j
post-50607-0-42820700-1419956984_thumb.j
I hope this guide was helpful, if i've missed anything or you have any questions please post here and I will endeavour to help the best I can.
Excellent step-by-step instructions but like you say why aren't they standard? Small cost on a luxury car.
These illuminated door cills aren't even standard on the IS300h Premier. You can buy them apparently.
Agree they should be standard across the range
It really is a shame they aren't standard, because it's such a simple thing and really stands out from the crowd, you wouldn't find these on a BMW or Audi without spending some ridiculous sum of money. Just another thing that Lexus can charge extra for I suppose.
The real challenge is getting the actual parts, Apparently they are discontinued by Lexus in the UK. you can buy them in the US however they don't ship here. So I found someone on Ebay breaking the car and brought from them.
Nice one Goerge
How about copy and pasting your write -up here.....then it will be easier for others to locate
http://www.lexusownersclub.co.uk/forum/tutorials/category/6-lexus-is-2005-onwards/
Thanks Normski I didn't realise there was a section for guides otherwise I would have posted there first!
Awesome timing!! I bought my illuminated sills a few days ago, just waiting for post man to turn up with them over the next couple of days.
I remeber seeing the plug when I pulled the plastic sill off... Didn't know it wasn't wired!! Why give u the plug if they didn't even pre-wire the damn thing!
Your guide shall prove very useful indeed :)
Most RX's had them as standard so might be easier to find at a breakers
It does seem strange to have the plug there but stopping it from working on SE models only, I thought it might just be a fuse missing to start with but apparently the same fuse that does the courtesy lights also powers these.
I hope the guide is helpful, it's a nice upgrade to have.
I installed some LED Lexus Logo lights which are plug and play - 3 sec install and they look great - Thanks Normski for the recommendation.
Ebay £15 job done!!
installed mines last night after I got home from work.
Well happy with the result and running the extra cable was super easy :)
post-32321-0-55463300-1420639076_thumb.j
Hi Agent, how much did you buy the sills for and where? I remember they were so expensive when I was searching.
Must say looks good :)
I managed to pick them up on eBay for £36 delivered... You could say it was a steal :zorro: lol
Really happy with them, they were a bit filthy when they arrived but i spent a good while cleaning them up.
Agent That really was a steal! I paid £65 for Mine delivered.
They are hard to find in the UK, Although you can still buy them brand new in the US (They don't deliver to the UK, I already asked. )
If you are forced to go down the Ebay route and getting used ones, a bit of cutting compound on the brushed aluminium and some boot polish on the plastics make the world of difference.
I would assume so.
It does just pop off with clips, so it should be easy enough to find out.
The sill lights are illuminated by LED's, and as such are not made for replacement. They normally will outlast the life of the car. I fitted some to my Prius about 5 years ago. From memory they cost about £30 for a set of 4 on Ebay.
John
  • Similar Content
    • By pointer7
      Hi All, Newbie here!
      I used to have a 2003 IS200 which I traded in for a Saab 9-3 Aero.
      I miss my Lexus so I'm now looking for an IS250, I have heard that the trim levels can be quite confusing so does anyone have any tips/things to look out for? I have budgeted around £5k for one
    • By igotthechronicbythetree
      Hi all,
      I'm new to the forum and also the Lexus brand.
      I've just recently bought a 2010 IS250 F Sport with 34k (now 35k) miles. It's a commuter car for work as I drive on the M25 and A2 everyday in Kent, so needed a nice auto for the daily 64 mile round trip. It's Argento Silver with a lot of options on it as I wanted one with the nav and memory seats, saw plenty without them too.
      Only took pics this morning, needs a good wash, clay bar and wax:
      Loved it so far, very smooth and comfortable. The suspension seems a bit stiffer now I'm living with it daily, but it's still very compliant. It's more the potholes or nasty ridges in the road that vibrate through the cabin. Just sorted the door unlocking last night as it wouldn't open the passenger door when I stopped or opened my door. Now the doors lock when starting the engine and shifting out of park and lock when shifting into park on stopping the engine, perfect! MPG was good on the way back from Stockport, sitting at around 40-43 mpg over 250 miles of mostly motorway. On a new tank of more realistic town and motorway, it's around 32-33 mpg which I think is very good considering the engine size and being an auto.
      Things I love about the car - the looks, the seats, the 18 inch alloys, rear camera, Bluetooth streaming, electric seats and steering column, memory function, keyless entry and start.
      A quick query while I have some attention, do people use the ECT power mode switch or leave it as standard? Only just read about it last night on this forum, elsewhere and also in the Lexus manual.
      Any more hints and tips would be greatly appreciated!
      Hi all,
      I've been browsing the site for a little while and I'm currently looking at purchasing a 2010 Lexus IS250 F-Sport.
      I've had mostly Honda's and have always liked Lexus but haven't been able to afford one.
      I've had a good read of this thread - http://www.lexusownersclub.co.uk/forum/topic/108747-what-to-look-out-for-lexus-is250-2007-model-year/
      Were any of these issues fixed in a later 2010 model that I'm looking at possibly? Or was it an exhaustive list for this model, regardless of the year?
      The only other thing I'm factoring in is the alloy wheel refurbishment which seems inevitable and also the exhaust which would be replaced by a Tanabe exhaust I think as the standard replacement is so expensive.
      Any other advice apart from what I've read in that thread?
      The car I'm looking at buying has full Lexus History and has under 50k mileage. I would look to carry on the Lexus servicing as it appears as though they have fixed price servicing.
      Thanks,
    • By jamesm182
      The time has come to sell my lovely IS250 SE-L that I have owned for almost four years. Only selling due to purchasing an NX.
      The IS250 SE-L Multimedia Auto is widely regarded as the best spec for the 2nd gen IS, and I'm sure most regulars to the forum will know the spec, but just in case:
      - Full leather, electric, memory, heated, cooled seats
      - Electric/memory steering wheel adjustment
      - Sat nav, Bluetooth, Mark Levinson 14 speaker surround sound & DVD player
      - Front and rear sensors plus reverse camera
      - Electric rear blind
      - Xenon lights, LED rear lights
      - Powerfold electric and memory wing mirrors
      - Auto dimming rear view mirror and wing mirrors
      - Cruise control
      - Dual zone climate control
      - Smart/keyless entry and start
      - Auto lights and wipers
      There's probably more that I've forgotten to be honest - it has pretty much everything!
      The car has covered just over 66,000 miles and has a full service history - all but 1 being from the Lexus main dealer. It was last serviced at Lexus Poole in March, which was the major service including the spark plugs that need changing at 60k. The MOT is valid until 29th September 2018, also last completed at Lexus Poole so has had a recent Lexus health check and all clear. In fact it has been in again recently to have the airbag recall done so that's all sorted now too. I am the 4th keeper of the car and have owned it almost 4 years. The first keeper was Lexus Poole as it was originally their demo car. I have the fully stamped service book, all manuals/books and a stack of invoices to go with car, along with it's two remote keys.
      The car has also had a recent new alternator and water pump (fitted at Lexus Poole), recent new tyres all round, and recent front discs and pads. During my first year of ownership (when it was under Lexus warranty) it also had a new rear caliper, two new rear shocks, and 2 new Xenon bulbs, so it's had most of the common issues sorted.
      It drives beautifully and I have kept the car in very good condition. If you would like any more information on the car, more photos or would like to come and view it, please send me a PM and I will give you my mobile number. The car is located in Poole, Dorset and I'm looking for £5,995 ONO.
    • By joelfigueira
      Hi all,
      winter is fast approaching what do people do to there cars to stop the windows misting up as soon as you get in the car?
