Service
ukgs300
You need to ring around a few dealers as the price can vary. Price will depend on what is required. There is a full service but then there are also things that are done at set intervals such as every 20k miles or every 30k miles (e.g. brake fluid replacement, coolant replacement, gearbox oil etc).
Cambelt needs changing every 63k miles.
  • 3 months later...
Just had a 60k service and needed new rear brake pads in addition. Cambridge Lexus charged me £824.50
:ohmy:
Mine's due in about 3 weeks or so - bugger!
If I need new pads I'll get the green stuff one's thanks to the recommendations on here!
Ok Colin, will put something together in a bit, just got to sort some bits and bobs out for work so should be up around midnight - results shocked me a bit!
