Mpg Calculator
LennyLexus
Hi all,
Just a little tool I made for myself a while ago :mat: Thought I might share it with you all as I think there are a lot of dodgy mpgs being quoted :lol: Its very easy to use and you dont need to put much in. ;)
O you might need to rename the file extension to .xls
mpg_calc.xls1
  • 1 year later...
here's a few sites with similar features:-
http://www.robinwhite.fsnet.co.uk/conv/mpg...bmit2=Calculate
this one slightly better for alternate calculations:-
http://www.geocities.com/mpgcalc/
yet more calculations and could help with cost per mile etc...
http://www.torquecars.co.uk/Tuning/uk-mpg-calculator.php
Not checked the links out, but the easy way to check MPG quite acurately is :
Fill up - note the milage on the receipt
Use the fuel
Fill up again - note the milage
Your mpg is : the difference in milage/ fuel purchased 2nd time
You can work out p per mile this way
