Vibrating Midrange.. Help !
shars200
Hi All,
I have an rs200 with a Beams Engine. When driving in 3/4 gear at about 3/4500 revs and i take my foot of the accelarator i can feel a vibrating noise running through the car. Its ok at high revs and low revs and ok if i stick it into neutral.
Its not the wheels or the brakes.... anyone have a clue ??????
:unsure:
Any you guys had this problem mines has started to make vibrating noise only now and again seems to be more noticable between 60-40 mph.If you let car free wheel with no accelelation at that speed noise appears but dissapears under acceleration or by puting the clutch in.Seems like a propshaft problem but when inspected on ramp everything looks fine, mechanic in garage thinks propshaft but no visable clues.Any ideas or help appriciated !!!!!!!!
the fella dose my work noticed it on my motor when he checking for wheel bearing noise he told me that the drive shaft needs adjusted he say theres adjusters on it he doing mine next time its down
  • 10 months later...
