Cleaning the windscreen
Hi Guys, may I ask for your wisdom in explaining whether windscreen wipers should come on automatically when you activate the spray? I would have thought this is a given in any car of this era and yet my IS does not give me this. Is there a separate setting in the car that should be turned on?.. please forgive my ignorance here.. 馃檪聽Thanks in advance for any replies...聽
If you quickly spray the screen and the wipers don鈥檛 activate, you have to do it manually which seems a bit odd.
If you hold the spray for a second or two then the wipers activate and sweep three or four times, they then wait a few seconds and do one more sweep
Great! Tanks so much for the reply. I'll try this tonight 馃檪聽Much appreciated! So this would mean it goes one聽better than a BMW... there is no additional sweep after the first 3 in a Beemer... nice one 馃檪
Yes they should come on automatically as Jason has explained.
On the 430 a few seconds after the final sweep the wipers tuck themselves under the bonnet.
I would say the wipers should activate within 1-2 seconds of pressing the spray button - obviously if the don't come on at all then you have a fault.
On the BMWs - if you want auto wipers you have to physically press the auto button every time you use them as it resets when you turn the ignition off. On the 430 I rarely have to touch the wipers or lights button.
Is your Handbook silent on the issue B ?
Thanks guys... I did try the longer spray and lo and behold it works.... even got the 4th sweep after about 3-4 secs. TBH I did not consult the handbook Roy... ooops.. too lazy I guess. But thank you all!!! 馃檪
  • 1 month later...
聽 Pasted as rich text. 聽聽Paste as plain text instead
聽 Only 75 emoji are allowed.
聽 Your link has been automatically embedded. 聽聽Display as a link instead
聽 Your previous content has been restored. 聽聽Clear editor
聽 You cannot paste images directly. Upload or insert images from URL.
聽Share
