Air con re-charge 2010 RX450
Hi Just had my 100,000 service completed at Lexus Bristol. I had noticed a noisy ventilation fan when the air-con was on. On investigation there is a leak so the quote is....
My quote was £232 for the high pressure hose which was leaking and £80 for a re gas of the system total £312 + VAT.
Why are these hoses so special and so expensive?
jack
Maybe get a 2nd quote from a trusted, local specialist?
Lexus will replace, someone else might 'fix' it?
Thanks for the reply Piers!
Can any one in Cardiff recommend a local specialist?
jack
