markeyszoo 36 Posted December 6, 2020 Share Posted December 6, 2020 I struggle reversing out of a narrow drive in the dark. I have the rear lights with the “L” shaped reverse lights. They are not very bright and was considering wiring in a pair of LED daylight lamps under the number plate to come on when they do. OR is there a better lamp that will fit and not melt my lenses? Quote Link to post Share on other sites
jumbojake 102 Posted December 6, 2020 Share Posted December 6, 2020 Mine is also awful, but I found the camera is excellent in the dark.. doesn't yours have the camera? (can't remember what year they came in, but SE-L used to be a high spec) to improve light, might be worth seeing if there is a LED bulb replacement, but higher output. Quote Link to post Share on other sites
markeyszoo 36 Posted December 6, 2020 Author Share Posted December 6, 2020 Yes have camera but not over bright lights Quote Link to post Share on other sites
Mr Vlad 273 Posted December 7, 2020 Share Posted December 7, 2020 I'm confused about you having L shaped reversing lights. Has your car got aftermarket rear lights like the Vland? I find my reversing lights are quite good in the dark. Have you tried reversing into your drive when its lighter outside? It'll be easier when its dark to drive out. Quote Link to post Share on other sites
PCM 659 Posted December 7, 2020 Share Posted December 7, 2020 Some say... have your hazards on when reversing - more light and a warning to others? If it's a dark lane? Quote Link to post Share on other sites
markeyszoo 36 Posted December 7, 2020 Author Share Posted December 7, 2020 L shape is the white lens as pic. Hazards might warn others but being seen is not the problem, seeing adjacent fences is the problem. 1 Quote Link to post Share on other sites
Linas.P 1,360 Posted December 7, 2020 Share Posted December 7, 2020 1 hour ago, Mr Vlad said: I'm confused about you having L shaped reversing lights. Has your car got aftermarket rear lights like the Vland L-finesse design of tail-lights came in 2009. Mike - I am sorry to sound obvious, but you should not be reversing into main road from driveway, it is extremely annoying and dangerous. I know that is not exactly your question, but the best practice would be to reverse into the driveway when you park so that when you need to leave you can have front of your car forwards. That is as well compliant with highway code: Quote Rule 201: Do not reverse from a side road into a main road. When using a driveway, reverse in and drive out if you can. Your idea of having powerful light on the back of your car may be MOT failure, so perhaps better idea is to have lights fitted near the exit of your driveway and not on your car (that is if you insist reversing out of the driveway). Quote Link to post Share on other sites
markeyszoo 36 Posted December 7, 2020 Author Share Posted December 7, 2020 3 hours ago, Linas.P said: L-finesse design of tail-lights came in 2009. Mike - I am sorry to sound obvious, but you should not be reversing into main road from driveway, it is extremely annoying and dangerous. I know that is not exactly your question, but the best practice would be to reverse into the driveway when you park so that when you need to leave you can have front of your car forwards. That is as well compliant with highway code: Your idea of having powerful light on the back of your car may be MOT failure, so perhaps better idea is to have lights fitted near the exit of your driveway and not on your car (that is if you insist reversing out of the driveway). thanks for the lesson but i am also having the problem reversing into the narrow drive in the dark. Quote Link to post Share on other sites
Linas.P 1,360 Posted December 7, 2020 Share Posted December 7, 2020 20 hours ago, markeyszoo said: I struggle reversing out of a narrow drive in the dark. Sorry, I am sure you already knew what I said, however I didn't assume it - that is what you said. I actually double cheeked it whenever you said "in" or "out" before making the comment. Regardless, my suggestion would remain the same - get yourself a light with motion detention somewhere convenient to fit on the driveway and it will light it-up. Modifying light on the car will be more difficult. Quote Link to post Share on other sites
scudney 307 Posted December 7, 2020 Share Posted December 7, 2020 Reversing lights are not meant to be overly bright,they are primarily meant to tell other road users what you are doing Quote Link to post Share on other sites
Mr Vlad 273 Posted December 8, 2020 Share Posted December 8, 2020 I was going to say just the same as Linas in that getting a motion detection outside light fitted. Very good security tool plus you'll see any obstacles. Quote Link to post Share on other sites
Marleez 14 Posted December 9, 2020 Share Posted December 9, 2020 I had the same taillights. I replaced with vland leds 20201202_092947.jpg Quote Link to post Share on other sites
Marleez 14 Posted December 9, 2020 Share Posted December 9, 2020 I replaced my L shaped lights for vlands. The LED reverse light is brighter and you get extra lighting on the side of rear lights too. Quote Link to post Share on other sites
Marleez 14 Posted January 21 Share Posted January 21 On 12/6/2020 at 7:40 PM, markeyszoo said: I struggle reversing out of a narrow drive in the dark. I have the rear lights with the “L” shaped reverse lights. They are not very bright and was considering wiring in a pair of led daylight lamps under the number plate to come on when they do. OR is there a better lamp that will fit and not melt my lenses? I just seen this add on facebook for super bright LED reverse lights https://www.facebook.com/110369630821722/posts/162428048949213/ Quote Link to post Share on other sites
Yorkie740 34 Posted January 21 Share Posted January 21 www.autobulbsdirect.co.uk I buy all my bulbs from here just fit LED bulbs in the reverse lights there are a lot brighter than the standard bulb Quote Link to post Share on other sites
