Ceramic coatings
Had both my RCs ceramic coated from new. Definitely makes cleaning easier.
Don't expect it to protect against stone chips or scratches though
Having my Stinger done on the 1st of August, so can you let you know how it went then 🙂
Peter is right though, if you want damage mitigation then you will need PPF applied.
This is what I am having done:
https://www.tkdetailingcars.co.uk/new-car-coating-detail-5-year-warranty.html
It’s all a question of how much you want to invest.  As Peter says, it offers clear advantages over even the shiniest of wax finishes.
But if you do a high mileage and thus expose the car to increased risk of damage, then it’s also worth considering PPF for the front bumper area.  It has a degree of self-healing to offer.  The downside is that it requires more preparation to ensure the best possible paint surface, because the film will magnify any surface imperfections.
Something I didn’t consider when I had mine ‘Detailed’ is that it means an end to quick trips to the local car wash!  That ceramic finish needs a specific after-care routine.  So if it’s to be correctly maintained, there’s probably a bit more buying to be done.
Had mine detailed last year and finished with GYEON Q2 M -WET COAT. I used it myself during the winter one day and it was fine. During April, I used it again but the sun shone rather brightly and I never jet washed it, instead just used the hose spray.
What a mess I made of it. Hundreds of small flies settled on it and it just looked awful with dust particles settling on it.
In May I took it back to the detailer, who could only get rid of the mess by buffing it off. Instead of using GYEON again, he gave it a one year ceramic coating. It looks fantastic now and washing it is very easy. Doesn’t seem to get dirty with ceramic coating on it.
I think now that I have chosen the ceramic coating (finish), I have locked myself into it indefinitely. Taking it to the car wash now is not an option. I wash it with Carpro-reset intensive car shampoo, which is what the detailer uses.
