Now thats service!
Lexiguy
My SC went into Lexus Leeds today and had a service and mot.
They did a brilliant job with no problems on service or mot except saying the ns headlight was acceptable but a little high.
That may be due to the headlight being damaged or badly fitted. (I removed it to clean the dead fly out and fit upgraded bulbs... so it looks like fitting front parking sensors has moved up to the top of my list now so I can sort at the same time as the bumper is off)
I was able to have a good look under while on a ramp and it looked very good condition underneath.
No leaks or worn bushes.
I was surprised to see another two in there both silver!
At my request they fitted a pair of 20mm spacers on the rear wheels which has improved how the original factory wheels fit in the arches.
Great mini valet too!
I would recommend them to anyone, from reception, to technician, to manager!
  • Like 8
Just needs a turn of the beam alignment screw doesn't it?
Mine was in Tuesday 18th for the same, also in silver. Same tester, must be getting used to them by now.
When I went to collect it was parked up outside the front doors, it looked superb in the sunlight. I failed and didn't take a photo.
Don't worry about your failure Paul - - -
your *personal MOT/servicing isn't done at Domestic Road....
It'll be at the LGI!
Hi Paul
Joshua the technician was very knowledgeable about SC's, ultra helpful and polite!
I find the other staff just the same and look forward to my visits
Ant
