Wipers not clearing RHS
Ok, so went out in the heavy rain today and wipers were working hard. I noticed that when they swipe to the far right, they are about 3 inches (75 mm for the younger ones) short of the drivers pillar (as per video) which would create a wide no clearing zone if the windscreen was  very dirty / mud / snow / ice etc
So is this normal on the new NX? Has anyone else noticed this?
That's not normal but easy to fix. Normally the wiper should be parallel to the a pillar usually about an inch away.
Just needs the wiper arm removing from the splines and adjusting.
I used to do that myself in the 80's when I had a mini !
I will call my Lexus dealer and see if they can sort it.
I mean if you don't want to go to the dealer, say it's 1 hour away you can still do it. Won't be difficult at all
I know I could do it myself, have the tools and knowledge etc, used to do all my own car maintenance years ago, brakes, clutch, cylinder heads, engine swaps etc. But now I leave it all to Lexus, luckily for me I live 4 miles from one dealership and I work 2 miles from another.
5 hours ago, NemesisUK said:
I find it hard to believe it would leave the factory with incorrectly set wipers?  I'd say that's as designed ...
My 450h wipers are just the same. I thought it was strange they didn't clear the screen to the right.
I’d agree that it would be a poor piece of quality control to let that pass if it was an error.  And yet even in Japan that would leave a small unswept area in front of the driver.  So it’s equally hard to believe that it’s intentional.
With such a new car I would certainly give the problem back to the Dealer.  It may seem potentially just a minor adjustment, but any resulting damage or unforeseen consequences will only create bigger problems later on!
Turned up at dealer this morning for 2nd key appointment only to be told they have none with no eta. So instead they have adjusted my wipers while I have a nice coffee and biscuits.
  • Sad 2
