Hi all.
My IS250 weather seals are getting a bit past it, so I’m looking to replace them.
Does anyone know of a supplier?
Online they have been called so many different names.
So to be clear, it’s the rubber strips that are against the windows that move up and down.
30 minutes ago, BigDingus said:
Hi all.
This is a bit of a niche product, so you're most likely looking at OEM parts. Contact your local dealer. Or find a part number.
I think this could be it though.. https://www.amayama.com/en/part/toyota/7575353010
Roughly £50 shipped for RH side. OEM part from Japan. Your dealer could quote similar amount though so check. Part no. 75753-53010 (RH) 75754-53010 (LH)
If it's the finish that's deteriorated then black satin vinyl wrap works very well. I've successfully used it on my LS400 and BMW. If it's the rubber weatherseal that needs replacing then you could find it has a standard profile, which might be available from the likes of Woolies.
Texus, Saw this video last week. Excellent one.
I'd prefer to fit replacement ones.
Too much of a fidle for me.
Thanks though.
Howplum, they look ok. It's only when I roll the window they miss patches.
On my LS430 I replaced the outer rubber seals all around - I bought these from a Lexus dealer for abour £30 each - might be worth ringing the dealer as its a vehicle specific part.
Cruisermark. I’ve had too many bad experiences with Lexus.
Mirror for my RX was in the hundreds. I think it was about £200. Just the glass. Got one from a trader for £90. (New)
Sliding roof cables. Lexus was £600. Trader was £47. (New)
Lexus dealers rip people off.
