Rx450h+ series 5 questions
Hi
I'm thinking about buying a new 450h+ and have a few questions:
1. Any thoughts on whether the upgrade to Tamumi is worth it? There are a few extras I do not really care about, but I would be interested to hear thoughts on:
1.1 the adaptive variable suspension. How does it compare to the standard suspension? What extra settings does it have?
1.2 adaptive high beam - what is this like in practice? Is it similar to the the VW matrix system that effectively maintains high beam around oncoming vehicles?
2. Is it possible to set the regenerative braking to a level to effectively have 1 pedal driving?
3. Has anyone any experience with using brokers to source the car? I have seen amazing discounts with broker4cars and broadspeed, but they almost look to good to be true.
Many thanks 😊
Good evening
Personally I didn't think the Takumi grade was worth it and am delighted with the RX450h+ Premium Plus with Panoramic Roof that I have had since March.
Can't comment on the variable suspension but I am more than satisfied with the suspension on the Premium Plus. I previously drove a NX450h+ and I think that the combination of the bigger tyres and longer wheelbase gives the RX a better overall ride to waft along in true Lexus style!
Headlights are excellent and have never been " flashed at "by any oncoming cars.
Regenerative braking cannot be set to effectively provide one pedal driving as far as I am aware.
Lexus dealers are offering generous discounts on the RX at present along with low rate finance so I reckon bargaining with them should give you a good outcome.
Hi Ken
Thanks for your post. That's very reassuring to  hear about the excellent ride. Ride quality is high on my list, especially due to the current state of the roads!
Currently have a Rav4, it's just OK, but very noisy at motorway speeds.
Hi MrBee,
 I have the Takumi model (since summer last year). We chose this trim level for the following main reasons; Mark Levinson hi-fi, plush light interior with plenty of adjustability and adaptive suspension. We were going to have the panoramic roof anyway. All the other features were nice to have, however we were pleased to be able to get a decent price from the dealer.
There’s no clever adjustment available on the suspension aside from being able to select sport or normal. As a large, comfortable car it doesn’t feature adjustable dampers or wish bones etc.
Like KenR I have used the adaptive beams and had no problems with dazzling oncoming traffic and they do light up the road and signage very well.
I’ve no experience of using the brokers, but by discussing requirements with three Lexus dealers we got a price that was very attractive to us.
Thanks for the replies.
Another quick one:
Can you use Hey Lexus voice command to change the driving mode like "Hey Lexus, change driving mode to sport"?
I usually drive in Eco and change to Sport at the press of a button at busy junctions/roundabouts. But on the RX, this seems to be via the touchscreen which looks a bit of a pain.
Another quick one:
Never tried the voice command to change the modes
However, the screen does have a shortcut area where the most used functions will end up - you can change it to SPORT directly from there so exactly 2 touches
This isn’t listed in the manual as a voice command but I’ll give it a try on my next journey.
Thanks, appreciated ☺️
I heard the RX gets OTA updates, so I assume they do update things from time to time?
Yes, that’s correct. There was one earlier this year.
23 hours ago, MrBee said:
Hi
Many thanks 😊
To answer your questions:
1. I went for the Takumi because I wanted the ML audio system and the adaptive high beam system both of which are excellent.
1.1. The ride is better than my previous RX400h despite the 21" rims.
1.2. It works by chopping out regions where there are cars in front of you and coming the other way on the opposite carriageway, the hard shoulder remains illuminated to high beam levels and if you come to a road sign that section is boosted to give you really good illumination.  It's worked flawlessly since I took delivery last July.
2. Regenerative braking is not user adjustable but the car seems to make a good job of controlling it for you.
3. Not personally, but a friend has who says it's very difficult to get any kind of delivery date on popular models.
Alex.
Hi Alex
Thanks for your message.
I saw on some reviews that you can use the paddles to increase regeneration. But I guess you're essentially just going down gears to do this.
Another way to increase regeneration is to feather the brake pedal to the extent that the brake lights do not illuminate. The power/economy meter then shows an increase in power being generated. This particularly works on long downhill sections and slowing into roundabouts etc.
Thanks, yes, I do this in my rav4 👍
13 hours ago, MrBee said:
Hi Alex
I saw this on YouTube regarding adjusting regenerative braking:
https://youtu.be/4bSO-UFd_sA?si=i7VoYQp2RZ8eLl0A
I see that this is on the RZ, do you know if this has been applied to the RX also?
That's really interesting, I will have to try it out. I've checked the manual and it says nothing about doing this on the RX so maybe it's not been implemented.
Alex.
Oops, I did not notice that was for the RZ 🤪
Alex.
After some thought I realised it's not going to work on the RX, the paddles are used to control the E-CVT ratio. The RZ has a single speed automatic transmission as there's no petrol engine so Lexus added the regeneration control so the paddles could be retained in the RZ.
Alex.
Hi
I have found that you can customise the steering wheel buttons, so for example, one could be for Sport mode and one for Eco. See this link - about 7.5mins in.
This looks like the best solution. I’ve just tried talking to the car and none of “select sports mode”, “select driving mode sports”, “select driving mode” worked might just be my Berkshire twang though 😉.
 I also tried using the paddles but as AWC says they only change the virtual gears, and then only when S has been selected on the “gearstick”.
