Pull the whole ashtray assembly out and then you will be able to pull out the surround (pull up at the back when the switches are and then pull up and backwards to release from where it locates near the stereo). It will only come up a small amount, enough to get your hands in to disconnect the wiring going to the switches. Once they are disconnected the whole thing will lift away.
