I Blew My Engine!
SpOcK
Bad news spOck, I hope you will get it sorted soon
If I'd like to be street legal for Austria..... I would have to rebuild it back to a 155HP IS200 N/A with stock filter. :crybaby:
Same thing for me in France :(
  • 5 weeks later...
The engine's now been taken out of the engine bay and disassembled. Here are a few pictures (sorry for the quality, mobilephone cam...):
Engine with valve cover removed:
Some of the removed stuff in a box (intake manifold, throttle body, fuel rail...):
Draining the oil before taking the oil sump out:
The hole in the block (due to snapped rod): :sick:
That :tsktsk: snapped rod:
Everything disassembled:
  • 3 months later...
BACK IN BUSINESS! :) Well, sort of... :yawn:
Today I FINALLY got my new pistons! I ordered them late November, and it was supposed to take 4-5 weeks, instead the delivery turned out to be 4,5 months! :tsktsk:
They were made to order by Ross Racing Pistons USA. Quality seems superb and they came with unique 4 page measurements report. All pistons weigh within 0,8 grams from each other, so the tolerance is about 0,3%.
Conrods (of which I've posted earlier) were also made to order locally here in Finland, and they weigh within 0,4 grams from each other, making the tolerance only mere 0,007%!!! :blink: Quite impressive.
Combining lighter rod with a heavier piston and pin in different combinations, I was able to make every rod+pin+piston combination within 0,3 grams from each other. Quite good given that original rods alone can weigh as much as 10g's from each other.
Before I hear someone yell "TTIWWP", here are some pics of my beauties:
The box:
The contents with rings and pin locks:
The inside:
The whole sixtet:
Check out that beauty: B)
Kinda hard to tell the original from the new ones...
so when is the install mate
As soon as I get the new block (thanks Matt and Dave) dismantled. Then I'll take the block to the workshop to be overbored (new pistons are 0,5mm over-sized) and honed. After the pistons fit the block I'll put it back together and under the bonnet it goes... :)
What is the difference in weight between oem and new rods? And compared together with the pistons?
Haven't weighed the pistons against the OEM, but rods are ~100g heavier than the OEM. Someone might say that's heavy, but I don't mind cause I know that these rods will take over 200hp/rod (that's 1200hp in total), whereas the OEM wouldn't even take 50hp... B)
Looking very nice mate....... :D How much did the "pistons" cost you :whistling: as i will be doing this, before the end of the year :winky:
You've a PM.
Cracking stuff Spock. I have just turned green all over.
I would also be interested in the cost of these pistons and rods as I am looking at a rebuild soon my self.
Hope you get it back up and running asap so we can see the potential of the rebuild!!!
May I ask how much the conrods and pistons cost you also? As I'm going down this route soon also
Rods ~1200€ (handmade in Finland with a 0.007% tolerance)
Pistons ~1200€ (incl. rings and pins)
