Is200 Turbo
  • Replies 405
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Well what a fun day :crying:
Went and got Engine crane, £45 for the weekend, not to bad really. then started the lifting,
I supported the gearbox with a trolly jack. and all was going well, got the engine as high as we could then started undoing the hundreds of bolt holding the sump on.
Sump still on
Sump off, this took FOREVER, selant holding it on was very very tuff to get off, just hope i did a good job of getting the new one back on, as well as they did first time.
New sump with Oil line for the turbo
Photo of the mess we had made :)
Dave might be able to help here, on the sandwich plate for the oil cooler, i thought there was a seperate one for adding a gauge sensor in it. When i un did the bolt there was some crazy spring etc inside.
The only thing i can think that it is, is the oil temperature divertor. Does anyone know???
Bit of a pain in the arse as now i havent got anywhere to added both sensors for oil temp and oil pressure.
Have order the sump nut one for the oil temp, but now need to either get this sandwich plate moddified or do something else which i havent thought of, any ideas guys ????
That would seem like an oil diverter to me but I am not completely sure.
Don't really know about the oil sensors. you could prob take the oil line to a hose specialist/supplier and get them to fit another T-piece in it for the oil pressure sensor. you could also do the same for the oil temp sensor but put it in the oil line for the cooler.
Just an idea but may not work.
The only thing is i can get a sump nut one for the temp thats fine, but i think i will need to get the sandwich plate modified as, if this is a oil temp divertor in the sandwich plate i can put any sensors after it or they'll only work once the sandwich plate has reached temperature nad letting oil through, a bit of a head scratcher LoL
hey mate what is the turbo manifole off. and how much did it cost . sorry i'm from australia and things are slow on lexus is200 here. and how much boost are you running
Its one from america i think, i believe that the prolex kit uses the same one if you ask gsportcars he should know as this kit is off him.
Boost is 0 at the moment lol but will be 0.4 bar as thats what the waste gate is set at, think u can run about 0.5 or 0.6 before the engine goes pop
HAVE YOU THOUGHT ABOUT RUNNING A 1GGTE BOTTOM END THEY ARE HEAPS STRONGER WHAT TURBO ARE YOU USING. DOES THE CAR GO BETTER THEN STOCK ANY WAY YOUR RIDE LOOKS HOT. CAN YOU FIND OUT WHAT CAR THE MANIFOLE CAME OUT OFF PLEASE
It is made for the IS200, ask either Dave who runs Prolex or gsportscar, who has added posts above, as i bought this second hand, im not sure where it came from originally.
Not thought about doing that what car is the 1G GTE from is it a early supra or something ???
The 1g-gte is from a 2.0 twin turbo mkiii supra and I think it also came in the soarer aswell. Elliot you can get parts for this engine very cheap from Australian forums.
Try toymods forum. You will have to do a search as I can't remember the exact address.
The manifold is from turbokits.com in the states. Last time I looked they had stopped advertising the is200 turbo kit but I am sure they will still supply them. Dave (prolex) should be able to source one for you if needed.
Well today had the afternoon off, rang the welder he said i need to take suspension and wheel off so he can cut and weld. So thats what we did :)
The is the bit that needs to be cut out and rewelded, the area to the left of the 2 bolt in middle of picture.
HKS strut on the floor with wheel and packet of crisps :)
The car jacked up very high lol a bit wobbly, but have since lowered and put a second support just incase the wind gets up in the night.
Also decided to fit this shiny new thing today :) thanks to marcus, there are a few bits that he probably couldnt get the polishing wheels into but they dont show when all the stuffs back ontop.
Horrid old dirty cover :(
Cams inside looked in pretty good nick, couldnt see much wear on anything, looked like new TBH.
Another
Shiney one back on, left the old gasket on as it look perfect and didnt really want to come off anyway, i'll keep an eye open for any leaks when i start her up first time.
Another, photos really dont do it justice it does look a lot better the only thing is now ive gotta do the rest of the engine Lol
Little piece i started to clean then the paint came off so i carried on and its pretty much as shiney as the rocker cover now which is good :)
Another all finished up with the little 90 degree bend back on, if u can see it that is lol
90 degrees looks lovely mate top piece of work
but you must stop kerbing those wheels lol
I know mate there proper f**ked at the moment in need of a referb and some new tires but that said i could probably buy some new ones with tires for similar price lol.
I really like the look of these
http://www.sussexjapclub.com/18-10-5j-enke...yre-vt2456.html
there bloomin lovely
Looking good B)
Make sure there is no swarf in the rocker cover. There is a kind of plate in it which you can't really get to. This is where the swarf was that blocked my oil and could have ****** my new engine. But it was caught early and just had a complete strip down and new oil cooler.
Just double check to be sure there's none in it mate ;)
Looking good B)
I checked it over couldnt see anything in there might take it off again just to check
the oil pressure sensor is located on the (oil filter) side of the engine, below the head are x2 knock sensors, the actual pressure sender is located behind the oil filter near to the coolant drain tap
the location may be slightly out im doing this from memory................
Cheers Fella i'll have a look tomro to see what size pipe and fittings i need.
looking good ellz.........you like it then, F* hard work that was, be the 1st and last one i do :crybaby: :winky: as to any bits in there, it was all covered up to stop anything geting in there + it was air blasted to make sure.....
Cheers Marcus looks like it must have taken a while :)
Ok i went under the car today and looked for this oil pressure switch. Think i found it, but I dont think i can plumb into it with the oil line ive got, Gav can u point out which one it is i have to screw your oil feed to??
In black is the switch i think, but i need a thread to screw on to this screws into the block.
In Red i dunno when i undid it red fluid came out the bottom bit
In green is a hose which goes from there up to just above the red thing.
in blue is the oil filter
Help me please.
This is the thing that has to go on
Gav can u tell me where to buy the middle and top one please as it has snapped, i was very angry when this happened, i just cnt leave things alone lol.
Another photo of the option i think it has to go on to
Any help would be great
red is coolant tap
black is switch, unscrew it, and fit adaptor
green is coolant pipe for the oil/water heat exchanger at the base of the oil filter
did you even bother to use my excellent picture to find the bits on your car.......... :shutit:
red is coolant tap
LoL yeah i did try but i think the sensor screws into the block where as i need a thread coming from the block if u see what i mean. doesnt matter now as i need the 2 bits as they snapped.
Anyone got any idea where to get them from, ive tried local garages but they had nout
red is coolant tap
yes try demon tweeks, you need an adaptor that screws into the block, in that you screw a union to plumb in the factory sensor, and whatever else it is your trying to fit............which is exactly what you have broken...... :yawn:
