Gear Selector
nhlnhla
I have a small problem I need help with. Sometimes a few days ago I engaged reverse in As200 and nothing happened. For a scary moment i thought the gearbox is dead.. then I put it back to Park and engaged Reverse and immediately it engaged. Its an on and off problem.. what I notice is when i put it to Park, after a few seconds there is a "click"... if i put reverse I after that "click" its fine, Reverse engages easily. I checked the oil its fine, is there something I need to check or adjust on the selector or something,.. like I said its on and off this problem..
Thanks. Well I confess I have not changed the oil since I got the car. I got it at 98 000km now its 107 000. will try oil change and update.
Haha not a problem bud, yeah do try and get the Transmission oil changed and see how that goes :)
Tried checking my linkages underneath and adjusting a little. Still problem persists.. sometimes occurs more when the car is not level. Any help
Would any one know if hooking up the car on the Diagnosis machine will pick up this problem?
