Correct Tyre Pressure
Mr-Lex
Just had 2 tyres replaced and the bloke at the garage said it was 38 at the back and 36 at the front <_< Seemed a bit high to me but I just let him get on with it. I will check in the manual later.
There is a sticker on the inside of the drivers door.
Just had 2 tyres replaced and the bloke at the garage said it was 38 at the back and 36 at the front  Seemed a bit high to me but I just let him get on with it. I will check in the manual later.
That's roughly what i got told too, but the tyres looked n felt like i was driving 4x4 wheels off-roader.. :lol::lol:
So i reduced the pressure to 33 alway round, feels ok n looks ok too.. (Don't understand the panel on the door - too many numbers :wacko::wacko: )
38!!!!!!!!!! far too high!!!! the decal is easy to understand - lots of numbers because it includes 16" tyres also. heavy load, normal load and different speeds.
as a rule for general everyday driving the pressure is 33PSI front and back.
38!!!!!!!!!!    far to high!!!!   the decal is easy to understand - lots of numbers because it includes 16" tyres also.  heavy load, normal load and different speeds.
33 sounds right to me. That's what they were before.
38 does feel like I'm driving a 4X4, :P will be reducing the pressure back down to 33PSI front and back.
  • 8 months later...
Right, from what I can gather from the door sticker is 33psi all around?? But when I checked mine, they were set at 38 from the dealer!!
I rang Sanj, he said try 35.. coz its in the middle :lol:
Can someone please confirm what the best setting is? I have the bridgestone tyres fitted by the dealer as standard, and I have the standard 17"s.
are you going by the book, or your personnal experience Col?
Because I've very rarely heard of people sticking to the recommend.
But I got to be a bit more careful now, as these tyres a bit more dearer then my old primeras :lol:
I think that's the book figure but the car seems fine on that setting - I've no need to change. That is with SP9000s. Maybe the Bridgestones work better on another pressure.
On the GS I lower it slightly to get a better ride.
Ah... Well the dealer did set to 38.. anyone with Bridgestones?
And when should I get them switched :question: (fronts to backs & vice versa)
If you rotate them then they will all wear evenly - expensive when you need to replace all 4
surely its cheaper (price per tyre) to buy 4 tyres then 2?
And roughly after how many miles, should you rotate them?
:question: and what about tyre pressures in dry and wet conditions... does less pressure give more grip in wet road conditions? :whistling:
I tend to check wear on the tyres also... If they're inflated a lot they'll wear out more in the middle of the tyre when driving at high speeds. So when I notice that I deflate them a bit to get them to wear out more on the outsides.
Hard inflated tyres also give more mileage... :yawn:
Greetz
Personally I think 38 is too high for this time of year. Too easy to lose the back end.
isnt that what T/C is for?
I have felt a scared taking onto the motorway in rain at certain times...
But i thought that was more to do with not having a RWD before
T/C isn't boy wonder since it will allow in certain situations to keep in control without the back end sliding out.
If, however, you turn in hard on a wet road surface, T/C on, and your back does break out, you'll need all the steering skills you have to keep it from spinning 180° SINCE YOU WILL LOOSE ACCELERATOR CONTROL due to the fact that that's just what the T/C does : it cuts the juice! NOT GOOD, in certain situations.
I prefer to drive with T/C on when I'm cruising and will not engage in hard turning.
Though I prefer to have T/C off if I would want it to be "possible" for the car to break out controllably since then you can manage the sliding by accelerator.
All this is quite difficult & tricky if you first start driving rwd cars. It would be nice to look for an large empty lot on a wet day to start experimenting with the different effects of turning and drifting, using T/C and without T/C.
I have always driven rwd cars and if you're in it for the sport and enjoyment of driving and don't see your car merely as a means of transportation, then you might find rwd the only way! :winky:
Greetz
