New To A Soarer With Problems
Keith93tt
Right i see this forum is pretty dead but i need help so here goes
i have bought a 93 soarer and there are a few problems!! To clarify it is a jap spec 2.5tt
Firstly the fuel guage does not seem to work at all, it flashes for a min or so after starting then shows compleatly empty with the yellow (ish) refil light on. So far i've found info on this been a problem on v8's but that may not help me
secondly my speedo is in kph i understand there is a converter i can get but need a source? and any advice?
thirdly (last for now!) my sterio! i've not yet got the band width extender but i'm getting so much feed back through the sterio its un-real. dont want to get bandwidth extender if i;m going to get same result! it is as if i can here the engine reving but mor electrical
Guys on here are friendly ( we are here as well though!!!)
http://soarercentral.com/cgi-bin/sc-forum/...s.cgi?pg=topics
Looks like the fuel gauge is a common problem and it could be the sender unit requiring cleaning
Here's the link for this section
http://soarercentral.com/cgi-bin/sc-forum/search.cgi
Speedo conversions can be done DIY if you are confident
Have a search here
http://www.google.co.uk/search?hl=en&q...yUK%7CcountryGB
Poor radio performance is normally due to bad earthing on the radio or the aerial so check all connections.
The frequency changers are on eBay for around £8.00 but if you want to get full UK coverage on FM you need the 18 Mhz one this will give you 88-108 Mhz ( UK spec)
Finally welcome to LOC and happy motoring
