Over 100k
Cathal
buying another is200, for my price range most of the cars are between 90-110,000miles just wondering wot is the relibility of the engines, if properly maintained should last for ever ye
Im pretty sure the manual says it should be replaced every 10k after its 1st replacement. That could probly be stretched to 20k but for the 'relatively' cheap price to replace the belt, its alot cheaper than replacing/rebuilding an engine!
Seriously?
Ive never heard that, why?
Seems unnecessary
Why ? if you are using all 3 lexus genuine parts at the change, then you will be ok until the next change is due :D
jus another qucik question,(so not to start another thread)
Got the car check online, checks out ok, the car is in NI and the registration starts with FD jus wondering where this is in the uk because its not a ni car
hi cathal,
FD..........forest&fens nottingham
Maybe I read it wrong! It did seem odd! Does any1 have a service manual to check in, if not il look tonight.
I did read it wrong! Its the drive belts that are replaced on 60k, then every 10k after that.
Timing belt is every 100k
sorry for panic/confusion!
