Heated Seats
Rikos
My friend was sat in the passenger seat on saturday night an they where complaining that there bum was cold from being sat on a wall. So i thought i'll wack on the heated seat and sort it out but they said that they couldnt feel it getting warm and i couldnt feel it to touch.
I am going to test it tomorrow but if it has stopped working what could it be? and is there any way of fixing it?
theres no link between the flashing seat belt light and the heater unit, as mine light never flashes and the heated seat still works.
im going with a loose connector under the seat!
DPTD switch.
Must vary between models - your heater comes on with no-one sitting on the seat? What year is it?
Where is the connector located? Is it the one at the front?
Also, how do you remove the switches without breaking them?
As for the connectors under the seat, sorry mate - no idea! Never taken one off to be honest. If you can't feel it, take a few upside down/underneath photographs with a camera and you might be able to spot something you can get a better feel for.
With the switches, you should just be able to pull the holder forward and it pops out. (it held in with soft clips). The connectors just clip off the back of them by pushing down on a plastic latch type thing in the centre of the connector itself.
Have you got the housing out? Once this is out you can just swap the connectors at the back of each switch.
If you get your hand underneath, sort of push up and pull toward you at the same time. Here's a pic of it out. (ignore the round switch, that is off another project)
Cheers for the pic, i just couldnt find anywhere to get a grip on to pull but shall try on my lunch
as i said mate PUT YOU HAND UNDERNEATH THE TRAY, PALM SIDE UP PRESS AGAINST THE TRAY AND THEN PULL THE TRAY OUT its very easy
