Bulb Upgrade Advise
TommyH
There are many ebay, depending what you want. Just make sure you get the correct fitments, there is a thread on here if you search.
HIDs are very highly recommended and cost well under £50 delivered these days, if you can stretch to it, you will not regret it!
Hi stoney, thought the HID's were alot more expensive than £50, do you have a link i could look up,
Thanks for your advise matey.
Tommy
There are a few on ebay matey, here are some 9006 6000K HID's for the dipped beam, item number 150295766408
Thanks alot mate, are they quite easy to fit ? im not to mechanicaly minded.
Tommy
Yes mate there quite easy to fit, sometimes you just have to turn the bulb connector the other way round to work but quite a simple thing to do :) You'll be very supprised at how good they are once fitted and will wonder why you hadnt done it earlier :D
The only thing i would do when you do fit them, is pop it into a garage that can check the beam height as when i fitted mine 1 was quite high and the other was very low to the ground so they set them up for me and it didnt cost me a penny to do :D
