Bonnet Struts
redz_UK
Indeed I do, or will do when I meaure mine for you later :lol:
I will also take some pics of the end brackets too.
I think from memory..... 505mm total length
The force rating I have in mine for a standard bonnet is 210Nm, I'm sure 200-220 would be fine.
I have this info you may also find useful
http://www.strutsdirect.co.uk
gas struts - SD03-200***
- [2] Rod End Fitting Steel Ball - SBJ11
- [3] Tube End Fitting Steel Ball - SBJ11
- [4] Rod End Bracket Please select bracket...
- [5] Tube End Bracket Please select bracket...
Sub-Total: £43.66
that is a lot better price than i would have thought, keep thinking i need to sort something out with mine as it's got a carbon bonnet and i been using a broom handle for the past 6 months :blush:
Gas Struts - SD03-200***
Will all those bits definitely do the job ? And can you confirm that I don't need any brackets, just those steel ball ends ? I'm certainly interested.
Love the broom handle example though :lol:
Yeah you'll need the brackets as well. the ones that attach to the bonnet are specially made, you'd have to try and borrow a set to get a template.
Yes brackets would be needed, I will get around to taking some detailed pics shortly.
The reason the info I have provided above had no brackets, as I was looking at replacement struts as mine I bought secondhand were not strong enough,
but I had them re-gassed from 150n to 210N @ they do the job fine now. I had the original brackets from the kit.
thanks stav!!
cant get much better than that!!
looks like this is going to be the issue.. can get the struts for about £15 but no idea where to get this made...
:sad:
May strutsdirect could advise? Like I said, I'd be happy to split the costs to get these made up...
Slightly off on a tangent here... just got a set off struts for the car but been told to be careful as it could put too much stress on the bonnet causing it to snap. Oh its a carbon bonnet by the way.
So the question is, who's got a carbon bonnet with gas struts? Anyone?
it certainly hasnt affected any members cars with standard bonnets...
maybe you should sell em to me!!
first refusal if you do!!
:whistling:
:whistling:
Lol i ll keep you in mind mate!
i dont know of anyone, but Prolex do a bonnet strut kit for carbon bonnets, maybe ask him for advice?
cool might drop him a pm on here. cheers
