I will be looking to purchase an LS430 early in the New Year.
Will £5K get me a decent face lift model, or should I look at a lower mileage early model.
I will also be fitting LPG, is there anything that i should be concerned about.
p.s. is there a section on this website that shows photos of members cars, motified etc
Karl
(west yorlshire)
For that money you should be able to get a very good early model Ls430 looking at eBay at the moment, dont forget auto trader as a source, thats where i got mine from.
I have (under repair, drink and mobile phones thread) a 53 plate 430, 60k miles, all the bells and whistles i need and more, and it has served me extremely well, no complaints at all.
The newer model you may just get a lower priced one.
As for LPG, it is on my list of things to do when i get the car back, but i think i will be going to Profess Autogas in South Wales.
Karl
(west yorlshire)
Be very careful about who you chose to install the LPG system.
There are lots of cowboys out there ready to fleece you of your money and leave you with a dangerous and sometimes useless system. Mike
Karl
(west yorlshire)
Hi
there is very good chance you will be able to pick a face lift for 5K - These cars come fully loaded - only some will have ACC/PCS
heres a checklist when buying
Check has full service history - and most importantly has had the cambelt changed - it should be done 100k or 10 years whichever is earlier
Check all electrics work expecially keyless entry
Check the aircon works front and rear as compressors fail
Check bonnet and boot struts hold up - the struts are a weak point
Check mirrors fold in and out as sometimes they stick
Check headlamp washers work - they rarely get used - but any problems can be used as a bargaining tool
Check parking sensors front and rear work - they tend to fail
Listen for any suspension clunks when test driving and gearbox changes should not be noticeable
Check the Hi/Lo suspension settings i.e car should rise when high is selected - there have been problems reported due to corroded electric connectors
Make sure you get locking wheel nut key
Make sure you find out the handsfree pairing code whilst there
Check theres no warning lights on (red triangle) on dash followed by message in orange
I got mine - a 04 plate with 112K for 3.5K - FSH
HTH
Karl
(west yorlshire)
Hi
HTH
& I'm still crying as I didn't phone them quick enough :msn-cry:
A couple of things to add to Mark's great list.
Also make sure you check the transmission and engine dip sticks - look for contamination in the oil etc.
If the car has done a lot of miles check the power steering fluid cooling pipe - it runs in front of the rad and will eventually rot and leak. It is expensive to replace but a hacksaw, a piece of rubber tube and two jubilee clips sort it out.
Drive it and give the brakes a good work out i.e. warm them up- the front disks can get a bit wobbley when warm - the car will stop but will not feel comfortable. I find the 430 eats front disks - don't let that put you off but you need to know. I use EBC disks and green stuff pads - you need to make sure the disks have less than 4 thou run out when fitted ot they will warp.
Good luck these are great cars.
Bren
