Rear Pads
topgun
could any one tell me how to replace the rear pads on the is200 had a go the other day but the retaining pins didnt want to tap all the way out of callipar. any help needed urgently as its nearly metal to metal cheers!!!
I had the same problem
it seemed the pin was slightly bent.
I should have got new ones but I just straightend it out and put it back in. fingers X'd its been ok
I check them every so often to be on the safe side :unsure:
