Speed Signal Wire
Just wondering if anyone knows what wire to tap into for my aftermarket cruise control , it needs to tap into the signal from G'box sender to Speedo (Manual G'Box) , the supplier says some cars have this signal on Pin No.1 of a Din standard stereo. Any of you got any ideas? :question:
I have no idea (I've been searching for it for a couple of weeks now) - but if you find out, please let me know.....
Hey, I'm offended,
Nobody thought to ask me.
Drivers side fusebox-second plug up from the bottom(closest to the bulkhead- Pin number 9,-Wire colour- White/Blue.
Hey, I'm offended,
:blush: - Sorry dude, totally forgot about asking you....
But once again Dunc, you have come the rescue! I shall try this out tomorrow....... :D
I think the wire DUNCAN is refering to may be the same as this one...
Location behind Instrument cluster
White connector
Pin 12 of 22 pin connector
white/blue 0.35mm2 wire
This is for ABS versions, Data supplied by ALPINE Electronics in their Speed Pulse Data disc.
