Advice re wiper blades please
Our beloved 2002 RX 300 appears to have non standard wiper blades - the ones that come up when you put in the reg no on reputable sites are the wrong lengths!
An old invoice shows the following wiper blade parts
85212-24090 and 85222 -48051
Can someone confirm exactly what size these are as I'm tearing my hair out here!
Thanks as always
Keith
Thank you. Can't disagree but somewhere down the line something's been changed and even the fittings aren't standard on the front!
Thats why I was trying to track down the exact part from the number if possible. May have to call Lexus
What do you mean by the fittings aren't standard?
They should just be the standard hook type fittings when you take the blade off. Someone has probably gone and put the wrong size blades on, if you change them to 24" and 21" you should be fine.
Maybe it's a rebadged Harrier?
The original wiper blades on my '92 MR2 didn't have hook and loop on the wiper arms, they had to be screwed on!
I just replaced the wiper arms in the end with some hook and loop ones from a later MR2.
Can you put a photo or two on of what you are dealing with?
