Induction Specs
whitie
as for the connector its the one that is pluged into the standard airbox (IAT sensore I think) all you need to do is extend the wire and then make a hole in the induction pipe and plug it in (somehow)
I take it you are going to have a bash at making one Whitie?
Got an actual sports part manufacturer making a test one up, I just need to find out the sizes. They can also make it out of whatever we want want.
Just need the sizes for the first one, then should be able to get them cheap after that :ph34r:
I've the trust one of alex, sorry i an't got the dimensions, but if your supplier can make one similar specs to this one, is it possible for you to get a heat shield made aswell?
If so i would like one of these and i am sure a few others would too.. ;)
