Squeal when slowing
Has anyone experienced a sound similar to a brake squeal but with no pressure on the pedal? I suspect it's regenerative braking that causes it but it's infrequent and I can't pin it down exactly. It's very loud and usually occurs when the car has been on a reasonable run.
Squeal from the brake area when not applying pressure is normally an indication that the pads are worn and the wear indicator is rubbing against the disc (as it is designed to do). However given the age of your vehicle I highly doubt that.
Regen braking occurs via the electric motor in the transaxle and therefore should be easily differentiated from the brakes and I'm not really sure how the motor could make that kind of noise without also doing it when operating to power the vehicle.
If the noise is coming from the brakes then I suspect your brake calliper/sliding pins are somewhat seized and therefore the pads aren't releasing away from the discs correctly.
I would recommend I visit to your dealer but being an intermittent issue they may struggle to recreate the issue and waste your time. Have you tried some hard braking from 60-10 a few time in a row to clean up the pads/discs and help free the pins?
Thanks for answering Colin. Only had the car for a short while and I am an extremely light braker but I'll give the vigorous braking a go. I haven't had any brake shoes/pads replaced in the last 20 odd years (5 or 6 vehicles) so I suppose that indicates how gentle my braking is. My last Lexus still had over 50% pads at 43000 miles!
Brake squeak/groan is common with hybrids and regen braking. As the mechanical brakes (pads and discs) are only applied at <5mph or in emergency situations the pads do tend to groan on application. Nothing much to be done but learn how to feather brake pressure to release pressure just before the car stops. I just live with it..
Interesting but I've never experienced this on the other 4 hybrids I've owned and I the squeal stops when the brakes are pressed hard (probably because the car stops almost instantly). It's going to the dealer on June 7th so we will see. Thanks for answering.
  • 3 months later...
Update on the 'squeak/squeal'. Dealer could find no issues and generally I haven't heard the noise - much' until yesterday. I drove through our village and heads were turning as the squeal was loud and persistent. Today none at all! When it occurred yesterday I did not have to touch the brake pedal and the noise was evident although never under acceleration. I am thinking it's the regenerative system that's at fault. It's booked in with our local Lexus garage on Friday when I will ask them to investigate, again.
Have you tried putting the car in neutral as that disables the regen brakes? You can then give the brakes a good workout without any regeneration.
I do this on my Prius from time to time. It’s amazing how different it feels with no regen brakes.
That could help me prove my theory Steppy. I'll give it a go.
  • 4 weeks later...
Yes, have had exactly this. Occurs after a drive of at least 5 miles and then becomes noticeable when driving at about 10 mph (often when returning home). Applying the brakes makes no difference and neither does steering right then left.
I doubt I will get anywhere going to the Lexus dealer as it is hard to replicate. I will report it to them at the next service in a few months.
There lies the answer to your Problem Colin  " You Are A Very Light Breaker " The brakes Not Being actuated With Any Force Resulted in The Pads Sticking on The discs Thereby causing the Squealing.. Its an Easy Fix...And not worthy of a visit to the Dealership In My Opinion...
  • 4 months later...
So I have had problems with heavy braking with a loud squeak noise, I’ve just had the front discs and pads changed and it’s still making the noise plus my UX is a2023 plate. It’s been to the dealer 3 times now and going foward is there a safety issue because Lexus can’t find anything else and have only changed pads and discs.
any suggestions what it could be ?
I suggest you drive the car going downhill backwards (on a no traffic road) with the gear in neutral and braking, this way the brake pads will realign and get rid of any glaze.
Why is there a safety issue going forward?
Explain how this happens.
Explain this please.  Where and how do the pads stick on the disc?
It's a mechanical way to realign the brake pads and clean them. It works on any car. On hybrid cars you need the gear in neutral so when braking you are only using the hydraulic system, bypassing the regenerative braking.
My problem hasn't recurred since the Lexus Leicester mechanic took the brakes apart to clean a 'channel' that he says holds the brake/road dust. I don't know where this Channel is but it seemed to do the trick.
58 minutes ago, Lmafudd said:
I'm on 199 posts - this one isn't for any good reason other than to move my count to 200! 199 seems unlucky to me!
You were right, brown envelope from the tax man tomorrow. Postal time lag effect.🤨
