Sign in to follow this
PhoneDrome
Changed My Spark Plugs To Denso Ik20
No comment.
Old plugs NGK IFR6A11 (90000 KM like recommended):
ALL the six and No. 5 an 6!!
New spark plugs: Denso iridium Power IK20
Just want to tell you to check the plugs before they look like mine. Or change them earlier. I'm not happy with the quality of NGK.
I thought Denso is OEM on Lexus? Not NGK :shutit:
Be sensible for your Motor. Have a sense for a nervously running engine on low revs. This is what mine did.
Belive me that I was very afraid as I saw the last spark plug. Couldn't belive it. Very sad.
But now I'm running on full power. Nice :hehe:
Where did you get yours from in the end ebay?
Yes ebay. LINK
12EA Spark plugs 101 Euro
Shipping and handling 18 Euro
TAX 14,71 Euro :(
It's no possible to get the IK20 in Germany. :duh:
Worth ckecking a plug or two every 20,000 miles just to see what they are like.
Your car should run much better on those new plugs :)
don't suppose if anyone knows if these plugs would work on an Altezza engine?
Service due soon!
You can get them (standard Denso iridium) from the dealers mate but they charge a premium.
You can get these plugs off eBay cheaper and they're better too (iridium Power vs standard iridium)
Didn't take long for mine to turn up and I'm happy with the IK20's.
Plus they'll be a good mod that you'd need when you get your charger :winky:
You can get them (standard Denso Iridium) from the dealers mate but they charge a premium.
You can get these plugs off eBay cheaper and they're better too (Iridium Power vs standard Iridium)
If i recall they are not that expensive from the dealers.
Still cheaper to get the better one's off eBay mate - think it was something like £12 a plug I paid at the dealers in my 60k service.
Can't find the reciept though.
The one's off eBay were better and cheaper.
Why can't everything off eBay be like that :P
Yep, bent over and done dry :crying:
I'll have to have a look now as it's doing my head in - does £60 sound more like it?
Can remember at the time I was gutted as I hadn't had the plugs replaced long before I had the IK20's fitted with the charger.
Ah found it - £9.07 + VAT each from the dealer :o
b***rd links not working.
basically type first search as IK20 and get the iridium result at £9.90
then when result appears.......
click x ref at bottom tab...
Any of these cheaper ones worthy?
results
Manufacturer Part Number Construction Gap Type Price
(per plug) Buy
Denso IK20 iridium centre electrode 1.1mm £9.9
x ref
Specified part information:
(per plug) Buy
Alternative part details:
NGK BKR6EP-11 Platinum tipped centre 1.1mm £7.9
Denso PK20PR-P11 Double platinum 1.1mm £7.77
NGK BKR6EIX-11 iridium centre electrode 1.1mm £7.59
Denso PK20R11 Double platinum 1.1mm £6.92
Denso PK20PR-11 Platinum tipped centre 1.1mm £6.92
NGK BKR6E-11 Standard 1.1mm £2.7
Denso K20PR-L11 Special design 1.1mm £1.71
Denso K20PR-U11 Standard 1.1mm £1.7
works out about £6 a plug if you get them from ebay.com
chucked in "worldwide" search on ebay.co.uk search page.
Got loads of results from US/canada....
So I am looking at iridium IK20 plugs x 6.
Is there any other model spec I am needing to be looking out for within the Denso ik20 range, eg a part number specific or anything?
With the next exact reply to assist me, I will then be a proud purchaser of some denso plugs before the day is out too!!!
:blush: If six are needed why are they sold in packs of 4 sorry if this is a bit duuhhhh :duh:
'cause some cars these fit onto, only have four cylinders?!? It appears to be for a wide range of Jap cars, and apparently fit the beemer as one seller on Ebay (us) stated....Civic's etc. :winky:
where did the broken-off bit on no.6 end up?
:o
No problem. They exploded into nano particles and didn' damage the cylinder.
I bought 3 packages of 4 and sold 6 of the IK20 to a friend ;)
My engine now runs nice and smooth (no wonder after these damaged sparke plugs). I like/recommend them. Now I have to see how much miles I am able to run on these plugs.
