Do I Have Any Volenteers ?
Chris.S
I haven't got access to a trailer and the cars stuck on the ramp at work.
I want to remove the charger so the guys at work can just do the engine swap, should make the job faster
remove air filter box and scoop
loosen belt tensioner
remove belt
loosen silicone pipework
undo 4 bolts at top
undo throttle linkage
lift out s/charger
cradle 3no. bolts
throttle inlet loosen silicone pipework and slide down pipe
easy peasy !
remove belt
undo 4 bolts at top
lift out s/charger
cradle 3no. bolts
easy peasy !
HMMMMMMMMMMMMMMMMMM, didnt i tell you that on wednesday :)
remove belt
undo 4 bolts at top
lift out s/charger
cradle 3no. bolts
easy peasy !
:lol::lol:
:blush:
guess what it worked !
now can i have the put it all back together instructions :D
remove belt
undo 4 bolts at top
lift out s/charger
cradle 3no. bolts
easy peasy !
:lol::lol:
:blush:
easy peasy !
slide silicone pipework down the pipe and tighten the clamp to the throttle inlet
fit cradel
lift in s/charger
do up 4 bolts at top
tighten throttle linkage
re-fit silicone pipework
re-fit belt
tighten belt tensioner
replace air filter box and scoop
remove belt
undo 4 bolts at top
lift out s/charger
cradle 3no. bolts
easy peasy !
:lol::lol:
:blush:
easy peasy !
fit cradel
lift in s/charger
re-fit belt
damn....... i knew i should have kept them bolts :D
Can pop down later if you like Chris but haven't got a clue what I'm doing?
Just waiting to find out if I'm at work or not at the minute though so that could stop me mate.
Sort of mate, hopefully my sat nav should be back up and running at some point today if I can get the receiver to do a full reset!
I'll see if I can find out what's going off today, we're waiting on someone to release some software and it's not there yet :(
If the engine is being LIFTED out Chris, you'll have to probally detach all the intercooler pipe work, but sure you can leave the bendy bit at the intake on mate, unless theres bolts underit where they have to seperate the top from the bottom of the engine.
Not hard to remove that piece, just an allen key mate, and a good wiggle afterwards and pull in an upright movement ..
If being DROPPED out Chris, still need to unde the Intercooler pipework so it will DROP out..
I think MAt C will be the best person to ask thereafter, as I have never taken an engine out before, only fitted and removed SC kit. Can help you fit it back at JAE.. Bring some tools etc if you like .
