Prolex-uk Kazama Muffler
Justin p
Its definantely made my mind up now so its just a case of waiting to see about the feedback regarding the prolex induction kit then it looks like its prolex all the way... :P
Webby
adie s car has the kazama & i test ftted the induction kit to it.........felt quite spritely :winky:
Webby
like you on the Viagra....so Aido tells me :tomato:
The baffle is held in by two small bolts - they can be unscrewed easily once the exhaust has been fitted, and if you want to put it back in cos you prefer the baffled note then its a doddle to do that too.
Thanks Mr Tomas, that's good news - did you have to jack the car up to do that?
Nope, it literaly takes seconds and as Colin P says it just slides into the end of the exhaust.
I haven't noticed any droning at motorway speeds with the baffle removed.
With regards to performance increases - it does seem more lively at the low to mid rev ranges (and pulling away is definitely better).
Better start saving up for the Prolex induction kit next. :D
Webby
Also has no pre-cats
That is good news - thanks for the info Mr Tomas
Mr Thomas in the video with the baffle out had you warmed up the exhaust pipe first (let it run for a bit or something).
Mines never is that loud when cold, but like it when warm, is that the only thing you've had done to your car?
Cheers Elliott
