Do The Is & Gs Have Same Alloy Wheel Fitments?
Had a quick scoot around the forums and can't really find the answer, there's not a lot of posts in the GS forum in relation to alloys..
So, can anyone please tell me whether alloys from the IS would fit straight onto a GS / Aristo?
Guessing they're similar due to the same brakes?
Thanks in advance :)
ALL Lexus models are
PCD 5 X 114
centre bore 60.1
Offset 38-45
iS
GS
LS
RX
Fitting wider wheels will change the offset. But so long as you stay within the variants 38-42 there will be no problem. Even then you can make modifications,spacers etc.
Bigger wheels ( say 17 to 19s ) Will stay the same offset unless they are wider.
i.e. 215s to 265s (7J to 8.5J )
PCD 5 X 114
centre bore 60.1
Offset 38-42
iS
GS
LS
RX
standard IS wheels are 45mm offset :whistling:
So you'll be keeping your wheels then...  :whistling:
S.
not sure the fiat punto has the same p.c.d , offset though
:whistling:
