Dodgy Start This Morning
Hi Guys,
My IS200 normally starts first time every time except this morning... The engine turns over and the car starts then it dies straight away :crybaby:
I try 2 more times with the same result, at the 3rd time i revved the engine a lot and it was fine from then on... Is it the cold weather or should i be slightly worried? The Battery seems fine and i recently changed the oil and oil filter.
Spark plugs perhaps?
This might not be the problem you have but anyway - I get something similar to what your describing every so often, for no reason at all it seems! its a known problem amongst LOC members, some members put the accelerator down fully then back up before starting which has cured the problem.
my primera had this problem when it rained very hard (only happend once though). it would turn/start then die. my girlfriends almera did the same. she couldnt get it going, i told her to floor it and start. sorted it out!
im guessing the exhaust filled with water and needed it kicking out.
