Has anyone fitted replacement LED rear lights? Some on ebay going for around £200 - £400. Any recomendations?
Buy these from the States, same kits, much cheaper.
http://cgi.ebay.com/ebaymotors/98-05-LEXUS...54498QQtcZphoto
Some LED kits have a taller clear section for the indicator/reverse light, which IMHO doesn't look as good.
These follow the original facelift profile.
If you're lucky you may avoid paying any VAT or Duty if they are sent via USPS, but in worst case, the total should only be around £160.
Has anyone fitted LED style rear lights and had trouble with the MOT? UK cars are supposed to have a 'E approved' markings on their lights.
Keep your stock lights and re-install them at MOT time, simple!
My bike's indicators aren't E marked, but the tester didn't even mention them. They work fine, they look fine (but nicer than standard) and I don't think testers care that much beyond that, E-marks or not.
  • 2 months later...
if I were you i would just upgrade the bulbs to LED....
if you get these LED lights you will probably have to wire up a resistor to each side, could cause you some problems
there has been issues with the led taillights for the is200.....so take your chances i suppose
...............as I said above there are DEPO copies which are rubbish
erm, Dave i didnt say yours failed, i said there has been issues, with ones fitted to the is200, 2 recently
I know................What I'm saying is there are cheap DEPO copies out there which sell for less than I h=get them for...............these fail
As you say buy cheap by twice.............
