Ta Ta Ta Ta Ta Ta........ When Start
Felix
Hi guys,
London 20:00 Friday night, I should on the way back to B'ham 1 hour ago, said good bye to my friends and went to the car park, turned the key:
ta ta ta ta ta ta ta ta ta ta...........................
again
Not a sound of engine turning at all.
there is something I noticed when I got in the car: the smell - smells like the Battery acid (quite storng)
called the RAC, jump-started it
I didn't stop in any service to have a rest, went all the way to B'ham.
Question is: is this a dead Battery or the starter mortor's teeth worn out or something else?
cheers guys.
deffinatly sounds like the Battery, if it smelt like Battery acid i would sugest getting your alternator checked down at your local garage check that its not overcharging your Battery, this happened to my focus a few years back, i went through about 4 batterys in 2 months, it was internally melting my Battery. get the Battery changed mate, see if that changes things and at the same time get the alternators charge checked.
thanks guys?
what's the size of the Battery should I get? any Recommendations on makes and where to get the best price?
also, to change the Battery, will I lose the info in the EMU and the code for the radio (if there is one which I don't know)
many thanks again..
just get 1 from the dealer - its quite cheap and has 3 year warranty.
the battery is dead and you will loose the radio presets and the odo but thats it - no radio code needed
lose the ODO? I suppose only the trip A and trip B, not the total.
anyone has any idea about the size of the Battery?
thanks
end of the story:
got one from the B'ham dealer, guess what? £57.25 inc VAT. 144.55 for fitting it.
so got the Battery and fitted it within 5 mins.
Job done, starts and runs perfectlly.
many thanks guys
comfirmed: lost Trip A and B and all radio settings and clock...... no radio code needed.
so what.............
