Confused With Tyre Pressures!
Is anyone confused with the tyre pressure recommendations in the manual?
So if I want to go no faster then 100mph then I should stick with the 2.3psi.
But if you're always travelling faster then 100mph, then you should have 2.6psi?
Why does lexus not have only 2 tyre pressures for fully loaded vehicle versus driver?
What are peeps running on their is200? I've just stuck with 2.3psi.
Forget the recommended tyre pressures in the owners manual and start with 35 psi all round. Monitor the tyre wear and adjust the pressures by 2 psi increments until tyre wear is even across the width. Increase the pressure if the tyres are wearing on the outer edges more than inner, and decrease if the wear is more in the centre of the tread.
