Head Light Jets
mrlukefulton
hi,
I have head light jets built into my bumper on my is200 (51 plate) but cant for the life of me figure out how to figure out how or if they work.
I've followed instructions saying to have your lights on the press the washer jets but just my wind screen jets work squirt, is it a big job if the jet pumps are non existent?
Also my Girl friend has one of those new Peugeots and her wind screen jets produce a mist covering the whole wind screen instead of the direct jet of water, and since im going to be respraying my bonnet quite soon im wondering whether I can get a set and install them weather they will work?
cheers
Luke
hi, there is a switch next to the rear fog light switch that operates the headlight washers,switch on your lights and press this switch,if they are in working order they should spray your headlights with a blast of water/screen washer.
right I looked for the switch but as you see on the picture the switch is non existent, so next thing im thinking is how can I install one? and get a system to work? Im an IMI trained stereo fitter so I shouldn't be difficult to wire something up. but without help im flying blind.
if I can sort out my head light jets im sure we can work summin out. I'm actually sorting out my Front Hub bearings, my flanges are both warped and keeps warping my disks, so I'm just changing both Front Hub Bearings. More flipping money. All good fun. But she's totally worth it. though im wanting to do I break fluid change, but don't know weather I should get my garage to do it or do it my self, if my self, what's the best device to change it with?
so the cap pulled off just as you presumed Funky_Monkey and I found a plug. its a flat 4 pin plug, so now its just finding a switch that the plug fits and fingers crossed it will work, I know its a long shot but a switch is what only what a couple of quid?
Gruntfuggly if you have a switch do you want to trade? coin holder for switch?
wow, 15 quid that a lot, Ian is there any way I can test if its working first? coz its a lot if it don't work. if u know what I mean.
It is rather steep Luke, if you understand wiring i can send you some diagrams.
