Is Aftermarket Suspension
Fidgits
Lowering Springs
The easiest and cheapest way to improve your cars looks and handling.
Eibach
Approx Cost: 150GBP
Lowers: 30mm
Ride Quality: Slight loss
Handling improvement: good improvement
Spax SSX
Approx Cost: 140GBP
Lowers: 25mm
Ride Quality: very slight loss
Pi
Approx Cost: 99GBP
Lowers: 25mm
Ride Quality: slight loss
Handling improvement: ?
HKS Sf5
Approx Cost: 230GBP
Lowers: ?
Ride Quality: ?
Fitting of lowering springs should cost between 100 - 200 GBP and take 3-4 hours.
Coilovers
Using a 'coil-over' damper, the ride height of the vehicle can be adjusted, ride height can be reduced much further than with just a spring kit as above. This allows a safe drop of up to 50mm, giving superior roadholding and handling.
TTE
Approx Cost: 1000GBP
Lowers: upto 50mm
Ride Quality: ?
HKS
Approx Cost: 2000GBP
Lowers: upto 50mm
Ride Quality: adjustable
Handling improvement: adjustable
TRD
Lowers: upto 50mm
Tein
Lowers: upto 50mm
Anti-roll bars
These bars dramatically reduce body roll through corners.
TTE
Approx Cost: 250GBP
HKS
Approx Cost: 500GBP
you forgot KW coilovers discussed in one of the lost threads :
Variante 2 : height 30-60 mm with damping adjustable rebound
Variante 3 : height 30-60 mm with damping adjustable rebound and compression
I have a few questions, according to need for speed they have Apex, H & R and also PI springs for the IS200, it says they all lower the car by 35mm but above the post has 25 for some.
Does anyone know which one is true as the Apex springs are only £87.13 excluding Gold discount. I'm presuming there cant really be that much difference between the ride quality of the spings?
