Tyre pressure warning light.
Today I had the Tyre pressure warning light come up.
I checked all tyres and pressures seemed ok, although I did put a bit more air in just to make sure.
The light is still showing though, how do I reset it ?  Most of the articles I see, talk of holding in the TPMS button, which my car doesn't have,  AFAIK.
It flashes once when  the ignition is turned on.
Maybe it's down to the weather ?
If you have an is300h the button is on the steering column. About a foot down from the wheel.
I think the button has to be pressed after engine off turn to IGN then hold button for about 3 to 5 seconds.
I've had tpms issues had to fix with techstream though to add new sensor.
Good luck
Sent from my SM-G965F using Tapatalk
Thanks for the reply. The problem is, there are so many versions of the is300h.
I  went over the road to the Lexus service centre and a chap kindly came out and showed me where the button is..
It is more or less where you said,  but very difficult to see. you would need a mirror in the footwell to be able to see it.
he said it's very common for the light to come on, as they are so sensitive. A lot of people just leave the light on, which
is ok until you get a puncture.
1 hour ago, NemesisUK said:
One only needs the reset button if one changes the benchmark pressure i.e. increasing pressures for full load conditions.
It can activate for a number of reasons, temperature changes being just one.
Indeed, check tyre pressure cold is a must.
Not had an issue with over-pressure, when temps drop winter time I always adjust.
I wonder what the tolerance is on the warning?
That's very true.
I was resetting mine with techstream and for a day or so the tpms would not illuminate when the car was running. Until day 2 then it would flash for a few minutes and stay lit constantly. This would go on until I next reset it. Then the same repetition would start again. I got the suspect faulty sensor changed. And the garage told me the car will learn about the new sensor. Tripe. A week later still hadn't changed the behaviour.
Perhaps on some cars that might be the case and works!? I don't know. Certainly my car wasn't learning any such thing.
Out came techstream and I inputted all sensor id 's into techstream wizard, it finally accepted all and the new tpms ID values and since then no issues.
Not a lot apparently. The chap who sorted mine out, says it's a very common issue.
Just a shame there's nothing (I could find) in the users manual.  I shall print something out for the benefit of the next owner.
8 hours ago, ianhu said:
That's very true.
How do you tell which sensor is giving the warning ?
They don't display in the cluster on my 2014 is300h, and I don't think anything is in the manual about displaying the individual pressures,. Just the warning light. I think displaying the pressures on the cluster came in more recent models. Although I would like to hear the same from someone who has the exact same model and year as mine.
Anyway, a guy at the tyre place had to check each wheel by holding a close proximity tpms tool. One didnt read and the other 3 did.
On the IS you don't.
It's just a case of warning you that the pressure is low so you need to check all 4 tyres. Could be more than one that is low.
Bloody lexus..... They gave the individual pressures in the cluster to more recent buyers of the same car.
Little things like that bug me.
My car came with no sat nav. They reckon it couldn't be added afterwards. Guess what... It can and was (by me) , small ecu update made it all work OEM style.
Did they? Because I don't think the facelift has individual tyre pressures available.
You can add sat nav to any Lexus. Most dealers aren't prepared to do this so will just say it can't be done. Makes sense to me though, just get a car with a better spec.
I got this car roughly 3k cheaper because it was repossessed by finance company from the previous owner. Then £250 for the second hand nav unit.
Yes, I've just found that out. Today is a lot cooler than yesterday, and the warning came back on. At least I know
how to cancel it now. 🙂  I assume when you cancel the light, that resets the pressure limits. ?
I'm not sure what the pressures should be on mine, with Dunlop sports fitted. I can't make head nor tail of the figures on the door pillar.
I have them at about 34 psi at the moment.
Pretty sure they should be 36psi. Reset after filling up otherwise it won't give a warning as soon.
Then just leave it. You don't need to keep resetting every time you top up
58 minutes ago, Hadrian said:
At least I know how to cancel it now. 🙂  I assume when you cancel the light, that resets the pressure limits. ?
One can cancel the light by increasing the tyre pressure to above the set pressure. Each time one 'cancels' the warning by using the button one initialises the the system and the current tyre pressures are used as the new benchmark, whether they are correct or not.
Yes I imagined that was probably the case...........I'll go up to 36psi now
Thanks all.
  • 1 year later...
The problem starts once you reset the TPMS by pressing the button under the steering column. Most do this after a puncture repair. The trick is to lower the pressure in all 4 tyres to 26psi, reset the TPMS by pressing the button. After 3 flashes of the illuminated icon, release the button. Now inflate all 4  tyres to the recommended 36psi. That should now stop the TPMS warning light from coming on.
By doing that you are only going to get a warning if a pressure dropped to something like 22 psi. That is far from ideal.
  • Like 4
I have had this recurrent problem of the TPMS warning light coming on. I had used a home tyre inflator which was faulty. The tyres inflated to 36psi pressure were in reality only 28psi! So I had relied on my domestic inflator and should have been more vigilant. Mea Culpa!
