My ISF broke down today, Major transmission fluid leak!!!
6 hours ago, Texas said:
You just might be storing a perfectly good box then?
It looks like the oil line connection onto the rad may have failed (they can corrode and snap off, reading into it) so the box may have ran dry.
The other failures are the plastic end tanks opening up and chucking all the coolant out or the internal transmission cooler fracture where the coolant mixes with the oil.
