Gearoidmuar 7 Posted November 30, 2020 Share Posted November 30, 2020 You don't get a spacesaver tyre in the ES300h in Ireland, though the space is there for it. Does anyone know the specs of this wheel? My car has 17 inch wheels. Thanks in anticipation. Quote Link to post Share on other sites
steve2006 2,107 Posted December 2, 2020 Share Posted December 2, 2020 Standard Lexus fit ( it is only the CT and LS600h that are different). 114.3 PCD 5 stud, centre bore 60.1 and offset 50. If you have the space it would probably be cheaper to find a standard secondhand alloy and tyre. Also bear in mind you will need the jacking kit and wheel nut brace. Quote Link to post Share on other sites
Gearoidmuar 7 Posted December 3, 2020 Author Share Posted December 3, 2020 Thanks Steve. I just ordered one! Quote Link to post Share on other sites
SH20 170 Posted February 9 Share Posted February 9 I bought a GS450h space saver wheel on ebay for my ES. It has the same 5 hole bolt arrangement and whether on the front or rear hubs there is no conflict and plenty of space when it spins. Moreover the ES wheel bolts fit perfectly on the space saver wheel holes as the tapered bolt faces fit the tapered faces of the steel rim. I still retained the ES's original underfloor foam tool holder and just leave the space saver in the boot despite it's size. Quote Link to post Share on other sites
