Specialist Auto Electrician ? should we have a list of specialist known excellence in several fields ?
Gentlemen ......  this is proving incredibly elusive for me to find sadly in my part of Kent
I need one to identify my intermittent issue that's just a little more than bugging me !
There are those " Specialists " that are saying to cancel the booking for attention if it's not showing itself as a " permanent " problem two weeks before the day ........or later !
And another who looks brilliant on line, and local,  but apart from being able to send him by email, his phone seems unobtainable ......  guess covid or whatever :unsure:
So then, if anyone knows of a Kent based Specialist Auto Electrician, preferably local to me on Sheppey / Medway / Maidstone Kent then I would be so so grateful
Thank you
Thank you
I should think that most fault finding guys these days do not want to bother with intermittent faults as they can take days /weeks/ never to locate without going back to basics . Most diagnosticians are lost without their fault codes etc and just want the easy jobs that they can trace easily . I cant blame them . Intermittent faults can be a pig , and wont show when you want them to . Techstream is a great tool but you need experience as well . In the modern world this is becoming hard to find . !
PS:- What is your intermittent fault ?
  • Nick hi
From my posts from 31st January in the Post ISSUES AFTER HIBERNATION
  On 1/31/2021 at 3:44 PM, Malc said:
no other car " self heals "  quite like the Lexus Ls400
well guys .......  it's done it again today
Been a couple of weeks since she's been out and  about ...  started fine today, a bit warmer and sunny and dry ..  going to get some essential cat food at P-at- H a 5 mile drive ......  just approaching there and POP it all goes off again ............  so I didn't stop, just carried on home ..  at the traffic lights put her in P and when the lights change she won't move into Drive .... so I pressed the Gear Override button on the console and she pops into D ok and off I go .........  5 miles to home and radio works, cigar lighter works ( my phone charges in there )  but all else looks a bit " dead "  ...  just getting into my turning and BLIMEY  it all sparks into life again and seems fine :unsure:
So if it self heals it also likes playing around
Asked my indy and he says electrics not his strong point so I'm awaiting his positive suggestion
I guess it's a local Auto-Electrician I need then ?
Anyone know of one on Sheppey, Kent
Found a potential Specialist at Aylesford in Kent BUT they're estopped from doing stuff coz of lockdown .  maybe start again end February they tell me !
Let's wait and see then :unsure:
On 2/17/2021 at 12:25 PM, Malc said:
  • Nick hi
Hi Malc
I'd put my money on an intermittent engine ECU (duff capacitor, dry joint etc.) or one of the connections to it.  My wife’s Avensis has a duff body ECU which results in intermittent central locking operation.  The body ECU is part of the fuse box – I have a low mileage scrapper to refurb because Toyota want £1K to fix it.
There are 12 ECUs in a 400:
● ECU (ECM)
● Proportional Power Steering ECU
● Cruise Control ECU
● ABS or ABS/TRAC ECU
● Shift Lock ECU
● A/C ECU
● Body ECU
● Tilt/Telescope ECU
● Power Seat ECU
● Driver's Door ECU
● Front Passenger Door ECU
● Wireless Door Lock ECU
● Air Suspension ECU (if equipped)
The list may help you narrow down the fault.
You mentioned you could not select drive – check this URL out.  It is about converting a 400 to a manual gear box (nuts I know but it takes all sorts) 😊.  You can get an idea about how they are connected and what may stop you being able to select drive.
lextreme.com/forums/index.php?threads/tricking-the-ecu-with-5-speed-tranny.1301/
put www:// on the front of the URL above.
Some stuff on ECUs from our American pals:
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/726265-how-many-independent-ecus-in-ls400.html
I don’t have a 400 or 430 any more so cannot be much more help – however I have been an electrical and electronics engineer for a few decades and know what a pain intermittent faults are.
You could try a heat gun (hair dryer) or freeze spray on the engine ECU to see if you can make it fail – this is a standard troubleshooting technique.  You could open it up and see if you can spot any bulging or leaking caps.
Good luck mate – now I need to do some work 😊
Bren
update guys ........  driven some 58 miles today ...  pharmacy and other " essentials " ........  stopped halfway thru to fill with fuel too ......... that's been a long time coming
AND she behaved impeccably ....  no sign of my little gremlin .....  so what shall I do now ......  cancel the appt made for 11th March with a local garage electronics guy ( not specialist tho ) who said to give him 2 weeks notice and I should cancel 2 weeks before if it's not playing-up when I get the car to him !
ok update .......  I cancelled the 11th March appt and the chap was amazed and thankful I had called as he asked ....... overdue hearing back from the Aylesford Specialist .......... is he really worried about my issues I wonder 😷 ............ but having travelled some 40 miles today and no gremlins I'll leave things as they are and perhaps will leave this all in abeyance ftb ..........
Jeez, the ( mine anyway )  Lexus Ls400 is such a dream to drive ......  no wonder I'm happy travelling 000's of miles in her, whenever and wherever I can :thumbsup:
this guy feigned knowing anything about anything methinks 😲
he won't now respond to my simple request to look at my email and whatsapps to even say if he thinks he can consider looking at any of this ....  so I guess he just doesn't know what to say or do !  So much for being of any use auto eletrical specialist'wise eh !
If anyone needs to know who to avoid in Aylesford Kent .....  do please ask
yes I know you mentioned Electrum prior ......  the issue thankfully has evaporated at every subsequent trip I've done in her ......  I shall leave it all for now and if the gremlin reappears I'll sure consider Electrum
Thank you
Thank you
As you know Malc ....... the LS400 does repair itself!
