Tpms problem
Johnlex
So I have tpms sensors on my Lexus IS 250c.
i put my spare wheel on which is a standard valve.
There’s no light on dash or warning to say there’s a problem with the tpms.
there should be a icon constantly flashing ??
does anyone know what the issues could be please
2 minutes ago, NemesisUK said:
Is the TPMS equipped wheel in the boot?
No it’s a another 5 spoke Lexus alloy with tyre I bought as I have a 250c I have gel pump in boot
Does this system work with a wireless remote sensor in each of the car wheels tyre valve or via the abs ring detecting a out of sync wheel motion due to a different wheel diameter and calculating a pressure drop?
I think this Lexus article on the TPMS may answer these questions.
https://mag.lexus.co.uk/tyre-pressure-monitoring-system-what-is-tpms-and-how-does-it-work/
I'm understanding that on a 2009 car, even tho' it has TPMS it is not compulsory to function for the MOT ...  so you're ok on that score whatever issues you have with it's electronic wizadry functionality
Ok, appreciate the link and it calls the two systems ‘Direct’ and ‘Indirect’ it also states that all Lexus cars after 2012 are fitted with ‘Direct’ system. But Johnlex has a 2009 ( according to his profile!
1 hour ago, Johnlex said:
The point I’m making is I’ve put a non tpms sensor wheel on and it’s registered as if everything is ok ??
why ??
Could it be that the system simply responds to the TPMS valves that are sending a signal?  In other words, it doesn’t recognise that one valve is missing,  but only that the signals it’s receiving are correct.
Just my guess!
I suppose you could check by deliberately deflating one of the other wheels and see if that now comes up as a fault.
Just my guess!
Yes maybe the unit is confused
I’m told it’s behind the stereo head unit
i will deflate tyre near a pump at the petrol station to see if your theory is correct
very strange
Just my guess!
The light has now  come on afte 100miles of driving. Must of been a glitch in the system.
panic over everything works as it should
My system has a reset button under the dash and there is a procedure for its use.
However, when I did have to reset it after having new tyres, the tyre fitter simply said “Just drive around for a bit and it’ll reset itself.”
In my case it didn’t, hence how I discovered the reset button (it was tucked away in the Manual).  But the Fitter might have been right about other systems.
Whatever, glad to hear its been resolved.
In the RC300h (and I'd imagine other Lexus models with active TPMS) the TPMS "reset" button simply sets the current tyre pressure as the benchmark which the system checks against. When tyres are renewed and presumably inflated to the correct pressure, the system doesn't need to be "reset" as the benchmark level hasn't changed.
