Sign in to follow this
Colin P
How Can I Keep The Rear Clean?
Good Morning!
Since i've had my car the rear (bumper and boot) get dirty as soon as I start the engine up. After a 10 minute drive the bumper is covered (so you could write in it) in black powdery crap!
Presumably its all coming from the exhaust so what can I do to get rid of it? Does one of the pipes need replacing or something?
I thought it was the back box that was just really dirty but its the same since I've had the hiper fitted.
Is this a common problem? Never experienced this with any other car I have owned (all three of them!)
Colin
Black oily type dust, could be either an oil leak or the engine burning oil , as the exhaust gas exits the tail pipe it swirls round in the turbulance and sticks to the body work ;) , is the tail pipe oily ? .
doesnt seem to be from what I remember, i'll go and check now and report back! The hiper has only been on for around a thousand miles i'd say.
Oh i've never seen any oil on the driveway either if that makes a difference?
ok well it looks pretty much clean and there is no sign of any oil, just black 'soot' on the inside of the exhaust ready to get blown all over the back of the car.
It shouldn't run with a cloud of soot, it isn't a diesel ;)
Have you checked if the air filter isn't clogged with dirt/dust? The IS shouln't belch black smoke, in fact mine hardly produces any soot on the inside of the tailpipe.
Cheers,
RX-Men-8
Cheers,
RX-Men-8
I have an induction kit which hasnt been on that long so i dont have the standard air box anymore.
I don't get much dust etc on my rear bumper? :huh:
hmmm so could it maybe be the centre part of the exhaust or something? The car has done 38,000 miles if that helps in any way?
white cars a murder to keep clean,i would imagine its normal,my lex has black on the inside of the tail pipe,so does any car ive ever owned.
I noticed a lot of black bits around the back of mine when I first got it (Plat Ice). I found that keeping the car well polished reduced the problem quite a bit. (I did wonder if some of it was brake dust?)
My exhaust is quite black inside - think this is normal, also I believe IS's run fairly rich, from other comments I have seen here.
makes sense I suppose! It does get a weekly wash. I wouldnt be suprised if some of it was brake dust!
Mine was cleaned four days ago and the back end is now minging!
The mud flaps sort out the sides big time but there's nothing for the rear end - are you driving on lots of wet roads as I've noticed mine get's filthy if I just drive through a puddle.
the mudflaps def. help.
Today was obviously really sunny and dont think I drove over any water at all and its still covered in black stuff. I suppose i'll just have to live with it and ask about it at my next service just to be sure.
try to change to a good polish/sealant.
This will make your rear more slippery and will attract less dust.
Some of the wax will attract dust.
at the moment I use Meguiars three stage and the gold class stuff.
Think I might try the Zaino stuff as thats supposed to be better for lighter cars.
You can switch, but no Zaino available in the UK :P
my girlfriend is american and her dad is coming over in two weeks so he's bringing me some stuff!
i think that the Meg Gold stuff is using Carnauba wax. This gives an excellent shine, but also works like a magnet for dust.
Try a sealant ...
look at imi`s,if ye lean on his lex ye slip off. :P
I found that the Megs'NXT polish has good antistatic properties & cuts down a lot on the dust collection
from what i have seen the rear of the IS produces quite a lot of rough air due to the flat back and because of this "rough air" a whirlpool type of effect is generated at the rear of the car causing lots of dirt to be deposited on the boot/bumper area- i think that because u have a white car it is far more noticable, as for the exhaust tip mine has always been black on the inside - if it hasnt any black/brownish/grey etc deposits then the engine doesnt run!
